Decking Block While Keeping Numbers
Hi Everyone!
I'm in the process of rebuilding my 1969 L36 motor which blew a head gasket. There has been very minor damage to the block from the blown gasket and the rebuilder has told me there is a chance it may require decking. This motor is the original numbers matching motor so I need to keep the numbers at all cost. My machinist has told me its basically impossible to deck a block and keep the numbers using a non-CNC machine - Does any of you happen to know of shops around the Orange County/Los Angeles area that can accomplish this? I'm really hoping I dodged a bullet and that the damage is so minimal that is does not require decking. However, I think it's better to be prepared for the worst. Picture attached of the damage the head gasket did to the block. Pitting is very minor and is smooth to the touch. All I did after I removed the heads is took brake cleaner and rubbed the area very lightly with a rag.
Appreciate any help/insights you all can give! Thanks!
yes it can be done with the proper machining equiptment. I have a picture of it done but this new way of posting pictures here is a pain in the ***
Received 3,043 Likes
St. Jude Donor '05
QMP racing engines in Chatsworth has a CNC program to do just this. Used them many times.
818) 576-0816
818) 576-0816
Received 1,878 Likes
2017 C2 of Year Finalist
Clean it up and lay a straightedge across it and see if it's hurt. May be OK.
Ck head same way.
JIM
Ck head same way.
JIM
Regarding the heads - They've already been decked and are done. They are 1969 oval ports and came out to be 106cc after machining. I think he put 2.19s in to get those extra CCs.
Hi Fellas,
In case you were curious, I spoke with the machinist last night who informed me that the head gasket did not wound/damage the block enough to where it requires decking. Looks like I dodged a bullet.
Thanks!
Alex
Thanks!
Alex
St. Jude Donor '05
If you mag the heads and they arent cracked, Id surface them anyways just to make sure they are flat as possible. Not a have to but probably should thing.
Received 2,687 Likes
I know nothing at all about deck machining, but I find it very hard to believe in the modern world of CNC machining that you could not deck an engine, and retain the VIN number pad.....in fact, I don't believe it. If someone tells you that...go somewhere else.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
And absolute worst case scenario don’t agree to let anyone near the engine who doesn’t clearly agree the numbers will not be touched. Wrap the block up in plastic and replace it first.
