Who has 17" wheels on tehir C1? Post pics please
Old 07-18-2018, 04:07 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Default Who has 17" wheels on tehir C1? Post pics please
Looking at getting some AR TT II wheels in chrome in 17" diameter to replace the 15" Cragar S/S wheels I have had for decades. Mostly for more tire choices in the 17" tire.
Just not sure how they would look.
Thanks,
Doug
Old 07-18-2018, 04:31 PM
cbernhardt
cbernhardt's Avatar
C1 of Year Finalist (track prepared) 2019
Here is my '59 with 17" x 8.5" C5 wagon wheels, tires are 245/45ZR17, C4 suspension.
Old 07-18-2018, 05:52 PM
new vette 62
Support Corvetteforum!
new vette 62's Avatar
Front disc brakes and air shocks on rear. 17X8's all around. Backs will rub without air shocks, no issues on the front.
Old 07-18-2018, 06:40 PM
vettsplit 63
vettsplit 63's Avatar
Location: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
215/65-17 Goodyears
Old 07-18-2018, 09:27 PM
MrTrim
MrTrim's Avatar
Default 17 Torque Thrust
Here's my old 61' with 17x7 Torq Thrust II on it w/4" backspace. This was in 2002 and I had the wheels Chromed cause I hate polishing aluminum wheels. There is another picture in in "my pictures", just hit my name to look. No rubbing issues even being lowered. I cut 1 coil from the front and made custom lowering blocks for the rear.
Chris
Old 07-19-2018, 11:29 AM
AZDoug
AZDoug's Avatar
What is the tire height on those tires?
Thanks,
Doug
Chris
Old 07-19-2018, 11:50 AM
Dreaming60’s
Dreaming60’s's Avatar
C1 of Year Finalist (appearance mods) 2019
How is the ride with the 17" versus the 15" tires. Thought the shorter sidewall might make the ride harder?
BH
Old 07-19-2018, 01:39 PM
AZDoug
AZDoug's Avatar
BH
It will. I put 17" on Ferrari replacing the 14" rims,and kept the tire height the same. The ride is harsher, not bad, but more harsh.
You can consider increasing tire diameter. I current run 26" tall tires on 15" rims on the '61 and would go to ~27.5" tall (stock height) tires if I go to 17" rims, and install the '54 Chev drop spindles in front and lower the rear an inch at the same time. The taller tire should make up for the extra rim diameter.
Doug
Old 07-19-2018, 02:03 PM
Mikado463
Mikado463's Avatar
I know it's not a C1, but they are 17" TQ's .........
Old 07-19-2018, 04:45 PM
gilbybarr
gilbybarr's Avatar
Received 1,888 Likes on 795 Posts
Not mine.....a friend's.
Old 07-19-2018, 04:57 PM
AZDoug
AZDoug's Avatar
That doesn't look too bad.... and those look like the wheels i am considering.
Thanks,
Doug
Old 07-19-2018, 08:50 PM
MrTrim
MrTrim's Avatar
Thanks,
Doug
Doug,
i don't remember the sizes. I'll look in my old car files and see if I find the purchase receipt. But I do remember they were Kuhmo tires. They were the only manufacture that had matching tread design for both the front and rear. I know the rears were 1 or 2 sizes larger than the fronts.
Chris
Old 07-20-2018, 12:55 AM
PattiR
PattiR's Avatar
Originally Posted by vettsplit 63
215/65-17 Goodyears
Those wheels look great. Where did you get them? Who do I call?
Thanks,
Dennis
Dreaming60’s (07-20-2018)
Old 07-20-2018, 01:18 AM
Mark Nevill
Mark Nevill's Avatar
Default 17 inch Halibrands
17 inch diameter wheel/ 55 series tyre
Thanks,
Doug
Old 07-20-2018, 08:00 AM
Shultzie
Shultzie's Avatar
Very nice looking car, but I think with the fender flares there should be wider and maybe taller tires in the back. Maybe even 18's on the back.??
Old 07-20-2018, 08:19 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
Doug
Doug
tire selection will be important, if for no other reason than to avoid the rubber band look...
Bill
Old 07-20-2018, 10:21 AM
Dreaming60’s
Any issues with rub in the back? Obviously the front wheels are not as wide as the back. What size on both ends and what tires are you running. It looks really nice!
BH
To Who has 17" wheels on tehir C1? Post pics please
Old 07-20-2018, 12:30 PM
jet-tech
jet-tech's Avatar
My Dads 54 has 17" wheels
Old 07-20-2018, 10:38 PM
Mark Nevill
Default Tyres
[QUOTE=62cruiseer;1597633105]Any issues with rub in the back? Obviously the front wheels are not as wide as the back. What size on both ends and what tires are you running. It looks really nice!
The rims are eight inches wide on the rear and six inches on the front.
Tyres are two twenty five by fifty five and fronts are two one five by fifty five series. Apologies, cannot type number on here for some reason. The front tyre are a bit too wide for the rims. Two zero fives would be ideal. I had trouble finding a two zero five tyre with a sixty profile to keep the sidewall height as close as I could.
The rears are tight but I have a four link rear suspension which gives more clearance and only about two inches of upward travel. I do like the wheels very much. The stance of the vehicle helps too.
Good luck with your search. Some very nice examples on here to help you.
Cheers,
Mark.
Old 07-21-2018, 12:12 AM
gilbybarr
gilbybarr's Avatar
It was an old drag car......my friend got it and has been making many changes and fixes. It still seems to sit too high in the back (to me anyway).
Quick Reply: Who has 17" wheels on tehir C1? Post pics please
