Cleaning dusty car without washing.
Hey,
So I never used one before (waterless carwash), my car is just a little dusty from sitting around. I don't think it needs a bath persay. What are some decent products I can run out and buy real quick today and come home and handle it.
all I have right now is some detail spray.
Adam's Waterless Wash
I use Adam's Waterless Wash often.
Adam
Hey,
Former Vendor
If it's just dust, and the car is waxed, a California car duster (dust broom) works great.
I don't know how waterless carwash will react or do to my xpel so I have to research more.
I know there are differing opinions on this but I occasionally use the touchless automatic car wash at the gas station down the street. It's the kind with a wand that goes around and sprays the soap then rinses. Blow dries on the way out. I then drive the mile home and use the leaf blower to get the remaining water off then hit it with the detail spray. Looks like new and takes only 30 minutes.
My go to in this case is as follows:
Go to Walmart and get the $5.00 pump up garden sprayer....holds about 1 gallon of solution. Pick up some gallons of distilled water while you're there. I make my own detail spray/waterless rinse using about 3 ounces of Wolfgangs Uber Rinseless Wash (my favorite at this time) to a gallon of water. I stopped using the 32 ounce spray bottles because most of our vehicles are large SUV's and trucks and my hand would get tired of squeezing the handle on the little bottle. With the pressurized garden sprayer, I can pump it up once and it will spray two or three cars with rinseless wash solution. Super easy and quick to do a vehicle. Use very good quality and fluffy microfiber towels and turn them often to transfer the dust from the vehicle surface and into the fibers of the towels. Make sure you lightly mist both sides of the microfiber towel with your rinselss solution before touching the car.....much less likely to scratch the clearcoat with a damp towel versus a dry towel. Also, pre-spray any bad spots (bugs, sap, etc) to soften them up before you wipe them off.
You can't go wrong with any of the top quality rinseless washes such as Adams, etc. Technique is important to avoid scratching the clearcoat. Watch their videos and educate yourself on the correct technique.
thank you for the above advice. I will do that, it sounds like a good way to save water. I woke up this morning to find this...
lots of ash in the air due to the wildfires (like 30 miles away ) but it's still falling around here. I gotta give it a real wash, but I do appreciate the little touch up advice and tips in between. my car lives outdoors in a covered area. washing it 3 times a week is not ideal, it's a big waste of water imho.. and it's not cheap especially around here.
I been waterless for almost three years now. Got caught in rain and had to go to the car wash. I hit the rear window on my coup with the wand and dirt/mud streamed out like you would not believe. Same from all rubber trim areas and wheel wells. Now I wash every couple of month.
Thanks! WW is one of my favorite products!
https://adamspolishes.com/shop/exter...wel-combo.html
Adams waterless carwash on Xpel? is that going to be safe for the long term?
We've been getting covered with ash for the last 2 weeks from the other fires in the area. Be careful with ash on your car as it can be abrasive. Use a leaf blower or drive the car at speed to get most of it off before you do the spray and wipe routine.
Last night in the Fairfield/Vacaville area a large grass fire got withing 200 yards of my house....cops wanted us to evacuate but it wasn't that kind of fire (just short grass in open fields) and at least 15 houses would have had to burn before it got to mine so I had plenty of time to get out. Until houses start to go up or large trees start to send big embers into the sky, staying put to make sure no embers, etc landed in dry leaves or flammable material and keep things wet made more sense to me. Once houses and big trees start to up, the temps get much higher much faster and it's time for people to evacuate.
it's brutal out here right now. consistently hot every single day for like the last 3 weeks. Everything is freakin dry we really need some rain.
thank you for the tip
California Duster. Been using them for 20 years. No brainer, have 3 of them for each vehicle.
Cleaning Dusty Car
For light, fine dust and road film consider using a KozaK cloth. Just apply a light touch to the surface, not an aggressive polishing action, when using it.
https://www.autogeek.net/kozak.html?...SAAEgL51vD_BwE
Haven't washed my car in a couple of years now, been using Meguire's wash n' wax and a waffle microfiber cloth instead. Readily available at the local Wallyworld. So much easier than hose and bucket.
Best thing since sliced tofu.
I habe one somewhere in the garage, I take a look around for it! just been too busy with other projects, gonna wash her tomorrow and then try some suggested products above in between washes. I should get a car cover too... that's next on my list
