C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
UPP Twin 6281 2005 M6
Old 08-15-2018, 02:02 PM
Shikaitsu
Shikaitsu's Avatar
Default UPP Twin 6281 2005 M6
Title pretty much says it all. I've had my 2005 C6 for almost 2 years now and amassed several hours of seat time so I finally pulled the trigger on a project I've wanted to do for a long time. Car is pretty much full bolt on with the exception of any mods that would've conflicted with the UPP kit.
Current mod list:
FAST 102 Intake
FAST LSX fuel rails
BTR Stage 2 Turbo Camshaft
BTR Cam install kit (valve springs and pushrods)
Borla X Pipe
Hooker Blackheart Axleback
GS front end widebody
Carbon Creationz rear fenders
Z06 OEM brake system
APR GTC-500 71" Wing
I ordered the revised UPP kit from TPS with 96 lbs injectors and 6182 turbos. once it arrives I plan on doing a very in depth and informative step by step install on this thread both to chronicle the task myself and to provide others with detailed pictures who might be looking to do the same.
UPDATE 7/1/2019
Turbo Build starts on page 2 post 27
UPP Fuel System Build starts on page 9 post 165
Old 08-15-2018, 09:04 PM
Midnightc6
Midnightc6's Avatar
Subscribed
Old 08-16-2018, 09:52 AM
g23crawler
g23crawler's Avatar
Is this kit the one with turbos in the fenders or like the z06 kit and mounted up top in the engine bay?
Old 08-16-2018, 04:17 PM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
As we speak.........
Old 08-16-2018, 09:20 PM
no0one718
no0one718's Avatar
love it..
Old 08-17-2018, 08:56 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Ditch the fast and fuel rails unless you want to burn the car down.
mykream (02-18-2019)
Old 08-17-2018, 11:18 AM
Shikaitsu
Shikaitsu's Avatar
It's a fender mount kit. Car is a wet sump motor. I've had the FAST fuel rails for over a year and check them weekly for leaks and so far it's been dry. But all concerns are duly noted.
Old 08-17-2018, 12:14 PM
Shikaitsu
Shikaitsu's Avatar
That wouldn't happen to be my order would it? Haha
Old 08-20-2018, 04:33 PM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
Yup!
That box in the last pic there next to the pipes is yours with your clip board right above it. Almost done now, just waiting on injectors, and air filters I believe.
Old 08-20-2018, 10:10 PM
ysb02
ysb02's Avatar
Looks nice!
Did you clear coat the cf fenders? I was thinking of doing the same thing
Old 08-21-2018, 02:00 PM
Shikaitsu
Shikaitsu's Avatar
The CF fenders are on as they came, no cracks in the clear coat yet. They don't fit well, though so be prepared to fight with them or have a professional body shop install. I chose the latter and went with a highly acclaimed Corvette specialist body shop in the area and the carbon fenders still don't fit very well where the meet the hatch.
Old 08-21-2018, 02:03 PM
Shikaitsu
Shikaitsu's Avatar
Update (sort of) I don't have the kit yet but I've been reading up on Mishimoto's direct replacement radiator and decided to preorder mine while the price was still discounted. It also comes pre-notched for supercharged/turbocharged cars so I'll include the install in this thread as well with some insight and how compatible it is with the UPP kit.
Old 08-21-2018, 04:03 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Old 08-21-2018, 05:39 PM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
Those should be fine. The amount we move down on the radiator is minimal, and only the vertical section on there that's cut out. This was bigger on the C5's than the C6's since we drop and move the radiator forward already. Worst case you can shim the radiator drop brackets and move it down a touch more.
Old 08-24-2018, 08:36 PM
Quiky One
Quiky One's Avatar
Subd!
Old 08-25-2018, 03:39 PM
FourG63 97GST
FourG63 97GST's Avatar
beautiful build, subd
Old 08-25-2018, 06:50 PM
ILLUSHN
ILLUSHN's Avatar
To UPP Twin 6281 2005 M6
Old 09-04-2018, 12:18 PM
Shikaitsu
Shikaitsu's Avatar
Kit arrives today, gonna unbox and upload some pictures of everything it comes with so future buyers know what to expect. Tear down will begin this weekend.
Old 09-04-2018, 12:27 PM
g23crawler
g23crawler's Avatar
Im assuming this kit uses a scavenger pump? Curious are how the lines are ran and where the pump is mounted.
Old 09-04-2018, 12:32 PM
Shikaitsu
Shikaitsu's Avatar
UPP has a video on Youtube detailing most of the install process from start to finish. In their video the oil return pump is mounted on the frame rail and returns into the oil cap up top. The video is several years old however and features an older design of the kit which is the primary reason as to why I'm trying to be as detailed as possible because I couldn't find a ton of helpful pictures with the redesigned kit.
Quick Reply: UPP Twin 6281 2005 M6
