Key fob
St. Jude Donor '12
Key fob
how long should the battery last in the key fob? Mine is growing on 2 years old. The reason for the question is I was using the fob to put the top down on my 2017 vert and half way everything stopped. So I walked up to the car and started the process all over again to finish putting the top down.
I’d say if you get 2 years out of a battery, you’re doing well. I replace mine on average about once a year. I’ve also learned cheap batteries don’t last. I recent took one from a generic bulk box of CR2032 (for PC’s) from work. It was shot in about 6 months.
I almost locked myself out yesterday actually when I left my fob on the seat. I shut off the engine to hop out to grab something. If I didn’t get the “No Remote Detected” message, I would’ve been looking for a way to call OnStar to unlock me because my cell was also on the seat. I should get out of the habit of leaving the fob inside trusting it’s recognized.
Rebel Yell (09-09-2018)
Agree - Two years is time for a change, whether a low fob battery notice is on the display or not. My particular experience is that a 'low fob battery' code in the system will be set before the display has the low fob battery warning.
I replaced mine last evening after 3 years upon seeing the code on an obd scanner, and the fob battery voltage was indeed low. Separating the fob halves is easy and described in the owners manual. Clearly, I let that battery go way too long
Even once a year is good insurance - as the previous poster said, having the fob go blank is just not a good thing on a vette with its electric everything.
My experience is that the original battery lasts me about five years. Then I replace it with an energizer or duracell battery.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
I recommend a product called SmartTop. It allows you to press the FOB for 2-3 seconds and the top will go down as well as the windows. The bonus is that you can also put the top and windows UP with it and that is a blessing when you are racing to your car to put up the top as the rain is coming down. I was at a car show yesterday and a cloud came over. As a convertible owner, I watch for that stuff! I had walked over and put the trunk down and went back to my seat on the lawn. Sure enough, it started spitting. I just hit the FOB and the top came up and the windows closed. Luckily it was a spitter and went by without much coming down. I tapped the FOB again and resumed my conversation.
Elmer
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
I plan to change my Grand Sport battery at 2 years Just-In-Case with a quality battery. I have a coupe so no issues about a Vert top etc.
blkvet6 (09-10-2018)
I had an issue with my 2015 fob after 20 months. Voltage on that battery was 3.05v and the replacement was 3.3v, so based on that one experience I would say that it's time to change. Either way, make sure you have the app on your phone for remote unlocking, and I even keep my spare key (not fob) in a hidden location outside the car as a second line of defense.
I found my spare FOB battery (never used) at ~2 1/2 years was as weak as the cheap battery I had replaced in my always used FOB after ~ 1 3/4 years. My main FOB started not to open the door consistently and I had to put it in the slot to start. My never used spare FOB when I started using it soon after was not opening the door automatically and I had to press the open button.
In my case, I use an old analog battery checker that loads the battery (i.e. draws some current, depending on battery size) which is much better than straight OCV battery reading in assessing battery quality. In my case both read just barley above the Red Replace range. New quality batteries read fully in the Green OK range.
The poster who quoted his OCV readings were 3.05 for a 20 month old battery and 3.3 volts for a new one. Granted the digital volt meters you obviously both used are not necessarily super accurate BUT it appears the C7 FOB needs a relatively high voltage to work properly and consistently.
I got about two and a half years out of my fob battery. Friends that bought their cars about the same time as me, also had fob battery problems after
the two and a half year time frame.
My FOB's were three years old (since I purchased the car) on the 9th. Both would not activate the hatch push button and required pushing the unlock button to get the drivers door to open. I only used one FOB and the other was in storage. Both batteries tested 2.94 volts. New batteries tested 3.3 volts and now all functions are perfect.
BTW, car was built June 29, 2015.
Key Fob case won't snap back together
Changing a Fob battery takes about 10 seconds, but I've spent hours trying to get the case back together! One side and the bottom snapped together fine but not the other side. This is more than irritating and finding just the case seems impossible. If you know where I can purchase a new case please let me know. Thanks!.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Easy peasy
Speaking of key fobs, ... The dealer claimed they couldn't find my second key when I bought my brand new car! They sent me a brand new unprogrammed key fob a week later. I'm 5 hours drive away from that dealer. How can I get this key fob programmed without paying a local dealership to do so. Getting my selling dealer to pay for it is not an option .. (Long story)
Do the long program shown in here: http://forums.corvetteforum.com/c7-g...s-and-rke.html
Step 1, 2, and then 8.
Elmer
St. Jude Donor '12
I had to take my wifes car in for service yesterday she drives a cadillac suv. I get in her car and the DIC says change the fob battery Well I was on the way to the dealer for service so I told the wife that I would rather pay them to change the battery. So I don't break it. Anyway what I didn't know was the cadillac dealer does it for free on cars in for service. Then I ask if I could get my C7 fob done and was told to bring it in and they will change the battery no charge. In todays world and market a service like that as small as it is will make me come back.
