Slight bulges on sides of rear facia
I have a 2017 GS, and I just noticed a slight bulge on the side of the rear facia at the top (see photo). The car was never hit in any way. The same imperfection is on both sides. I've never noticed this before this weekend, and I almost always notice any imperfection, but it's hard to imagine these just appeared over time. As they are now, I don't plan to flag this as a warranty issue unless they get worse. Does anyone else have this same issue?
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Does it get more bulged out with heat? If so, you've got the dreaded ultrasonic weld separation issue
https://www.corvetteforum.com/forums...-increase.html
Mine started bulging like yours. Warming the panel (as in letting it heat in the sun) made it worse
Not normal. Warranty matter...
Vegas1500 (09-18-2018)
Received 5,219 Likes
Welcome to the age of flexi-plastics, if it isn't moving around, panel to panel. The fact it is equal on both sides suggests it's probably not panel movement. I have to wonder if it's been there (at least to some degree all along and you just noticed). I suspect the best bet is to monitor it and see if it gets worse. All the best.
I looked back and your picture and your description of a bulge. I don't know what "bulge" refers to in the pic (I cannot see such) but it appears to me that there is a wider panel gap toward the top then at the bottom. I went out and looked at my '18. It doesn't have that variance in gap. BUT, if your car were mine it would have to be a LOT worse than it seems to appear in the picture before I'd let a dealership muck around with it.
My 2017 GS has a slight bulge on the right side, none on the left, and noticeable only on the seam. Had I not read about it here I probably would never have noticed, as it isn't glaring and if it doesn't get worse I won't be letting a dealer muck around with it and potentially damage something else.
I don't think anyone but you would ever notice that. Maybe mention it to the dealer the next time you're there, so they can make note of it and then just watch for it to get worse.
That photo was taken in my work garage. Take notice of the reflection of the ceiling. It should be straight. The bulge isn’t major, but you can see it especially from some angles.
After the bulge started, how long did it take to come apart? My car is only one year old, so if it's the same problem I'm guessing it would get worse within the warranty period.
Received 19,309 Likes
'20-'21-'22-'23-'24
