Air conditioning
Old 09-21-2018, 01:26 PM
Armbar
7th Gear
Armbar's Avatar
Default Air conditioning
I have 2017 grandsport, when its hot out (90's) the air conditioning doesnt seem to be able to keep up. The car seens to blow luke warm air only.. Anyone else have this problem?
Old 09-21-2018, 01:30 PM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
With ac on max, temp on its lowest setting, blower speed on low, you should get somewhere around 42 degree air out of the center duct.
Old 09-21-2018, 02:17 PM
IM4A2Z
IM4A2Z's Avatar
Get Ceramic window tinting which will help a lot with heat from the sun! I really like Huper Optik. That will help the AC do a better job of keeping up.
defaria
defaria's Avatar
Received 1,203 Likes on 732 Posts
You probably need the AC serviced. They probably need to add Freon or something like that.
Old 09-21-2018, 02:23 PM
speed4tu
speed4tu's Avatar
If its a really hot day with the AC on full blast the car is a bit warm. Air coming out of the vents on mine is cold. Just so much heat coming from car and from center tunnel after a longer drive making it seem hotter. Ceramic tint helps some with this. im still considering getting my front windshield tinted as well to help out.
Old 09-21-2018, 03:53 PM
Larry/car
Larry/car's Avatar
My AC works great! I do use it in the manual control mode most of the time. The Auto setting is dependent on the sensor that needs to catch up with the interior air temperature until it works properly.
Old 09-21-2018, 03:56 PM
Sconn
Sconn's Avatar
My '17 GS ac works great. I've always been comfortable. The fact it's blowing luke warm air doesn't seem right. I'd have it checked out.
Old 09-21-2018, 05:41 PM
defaria
defaria's Avatar
I have no problems with Auto ('cept I think hitting auto a second time should turn it off) and I'm here in Phoenix. I get in the car, crank it up and the A/C comes on and cools me off. If anything the interior sensor is warmer than the outside air. I've recorded temps of 118 when it was only (and I say only) 112 or so...
Old 09-21-2018, 05:49 PM
JakeC7GS
JakeC7GS's Avatar
St. Jude Donor '17
During the Vegas summers I keep it set to LO on auto (crank temp all the way down) most of the time. Even with ceramic tint all around, setting it to anything else seemed to keep it a bit warm. I think I read something about the LO setting being the equivalent to MAX A/C on other vehicles.
Old 09-21-2018, 07:22 PM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes on 1,366 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
118 degree outside temps, transparent top and 35% tint on sides and rear and AC had ZERO issues keeping up
OP needs to have his checked
Old 09-21-2018, 08:10 PM
JakeC7GS
JakeC7GS's Avatar
St. Jude Donor '17
For sure, especially under warranty and free. Just a suggestion of something to try in the interim as 'cool' is quite subjective.
Old 09-21-2018, 10:14 PM
KenHorse
KenHorse's Avatar
True dat!
Old 09-22-2018, 08:54 AM
Kevin A Jones
Kevin A Jones's Avatar
Received 11,702 Likes on 5,595 Posts
Vert or Coup?
The AC on my 2017 GS Vert works great even on days when outside temp is approaching a 100.
Verts are better insulated than coups so interior cooling (with top up) isn't as much an issue.
I'd get it checked while under warranty. May need Freon. Notice any oily residue on lines, fittings or compressor?
If dealer finds low Freon, I'd still keep an eye on it as good chance there's a leak somewhere.
You could also have a faulty compressor.
Old 09-22-2018, 09:07 AM
michelve
michelve's Avatar
Same boat here, mine only cools down around 2am
To Air conditioning
Quick Reply: Air conditioning
