Drive on lift
Old 09-21-2018, 01:40 PM
saleen556
saleen556's Avatar
Received 2,202 Likes on 1,193 Posts
Default Drive on lift
Is it a problem installing an Xpipe on a drive on lift? Considering doing it myself on our neighbors.
Old 09-21-2018, 01:47 PM
tome
tome's Avatar
Couple of guys have used my lift for that purpose, and no issues. You should be good to go.
oldC5 (09-21-2018)
Old 09-21-2018, 01:50 PM
oldC5
Support Corvetteforum!
oldC5's Avatar
Received 1,226 Likes on 734 Posts
Did mine on my friend Tome lift. Took about an hour. Let the pipes cool down . LOL
rsvette12 (09-21-2018)
Old 09-21-2018, 01:51 PM
rsvette12
rsvette12's Avatar
Interesting how are you passing state inspections ?
Old 09-21-2018, 01:56 PM
oldC5
oldC5's Avatar
New car first six years no inspection.. On my 98 vert they never looked for x pipes. Kept OEM X pipe incase.
Old 09-21-2018, 01:59 PM
saleen556
saleen556's Avatar
Thanks guys. I’ll talk to him and make sure it fits. I’m keeping my stock one just in case it’s an issue with emissions. They just do the computer check here. Since it’ll still have the monitored cats it shouldn’t be an issue.
Old 09-21-2018, 02:07 PM
rsvette12
rsvette12's Avatar
Thats how they do it in California ? then you have to get them off - in Mass you have to get it inspected right way new or not - If I had to remove them and go backwards I wouldnt bother
Old 09-21-2018, 02:18 PM
oldC5
oldC5's Avatar
Sent u a PM.
Old 09-21-2018, 02:21 PM
Coach32
Coach32's Avatar
Speaking of drive-on lifts.....should I insist on a drive-on lift for routine maintenance, like oil changes? Many of the dealerships in my area use 4 point lifts and I’m just not comfortable with that.
Old 09-21-2018, 02:44 PM
KemahGT
KemahGT's Avatar
Depends on the state. Here in Texas they plug into your OBD port and look for faults. Since the mid pipe is downstream from the O2 sensors the car will not report any problem. Even if you do remove the cats the system can be fooled with exhaust/O2 sensor hacks.
Old 09-21-2018, 03:18 PM
rsvette12
rsvette12's Avatar
Thanks cameras recording here in Mass - cant get way with anything - not good - vette is to low should be interesting jacking it up and they have to doesnt matter if its a 2019 - all recorded welcome to the land of the free - not anymore
Old 09-21-2018, 07:42 PM
lakemg
lakemg's Avatar
Are you saying that they are visually inspected with cameras? Unless they really know their ****, I bet that most of them would not even know that the factory x-pipe is supposed to have a set of cats in it, especially if you still retain the primary cats.
Old 09-21-2018, 09:19 PM
DSOMDream
DSOMDream's Avatar
Get the hell out of Mass and welcome to Fl. I did and never looked back. No state inspection here! Paul
To Drive on lift
Quick Reply: Drive on lift
