C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
ECS Install - Trans cooler lines?
Old 09-21-2018, 07:17 PM
Pete2k_Z28
Pete2k_Z28's Avatar
Default ECS Install - Trans cooler lines?
For the life of me, I can't figure out what to do with, or how to bend, the trans cooler lines so the hose coming from the head unit will pass through. The top line I think I've got a plan for but that bottom one is jut right up the middle.
Also, the power steering line that loops around the cooler is also kind of in the way. I just see all of these hoses rubbing, doesn't seem like a clean system.
Ideas? Pic to follow....
Old 09-21-2018, 07:19 PM
Pete2k_Z28
Pete2k_Z28's Avatar
Pic
Old 09-21-2018, 08:08 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Been years since I've had those, but I think I went through them. Definitely possible to make it work nicely.
Old 09-21-2018, 08:20 PM
Ant-Man
Ant-Man's Avatar
Screw those things in all honestly, I got some puch-lok hose and the adapter from jegs and I've had it like that for 3+ years no issues.
https://www.summitracing.com/parts/hda-397 x 4
https://www.summitracing.com/parts/HDA-106 x 2
If I go in to change them I'll go with a braided line.. but like I said 3+ years no issues
Old 09-21-2018, 08:29 PM
Pete2k_Z28
Pete2k_Z28's Avatar
Thanks! I'm honestly about to s***can the entire trans cooler, the lines are also pinching between the headers and QuickTime bell also. Seems to be more trouble than it's worth for a car that's never going to see a road course. I'm starting to really hate this project.
Old 09-21-2018, 08:49 PM
Ant-Man
Ant-Man's Avatar
Yea exactly why I went with the rubber lines, I taped/zip tied them out of the way and made things a lot easier.
Old 09-21-2018, 08:54 PM
Pete2k_Z28
Pete2k_Z28's Avatar
Where did you cut your existing hardlines? And what did you do to prepare the ends of those lines for the hose? Did you put in a bubble flare or something on them? Really trying to get this car wrapped up by the end of the weekend so I can get it tuned up before FL2K and also I have a friend coming the week of October 8. Hopefully I can find these locally if I go this route.
Old 09-21-2018, 09:04 PM
Ant-Man
Ant-Man's Avatar
Nope. Those things i posted are all I used.
If you detach the lines right at the firewall the adapters just snap it with a U clip, same on my trans cooler(dewitts).
The section you pull out is like 5ft long lol, but I just cut them in half so I could get them out easier.
Old 09-22-2018, 02:11 PM
Pete2k_Z28
Pete2k_Z28's Avatar
Thanks again! Back to the garage to begin the cursing again
Old 09-22-2018, 04:42 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
yeah, those thing are a PITA. I left them on but I was really, really close to taking a saw to them and cutting the f'ing things out during the install.
Old 09-24-2018, 09:02 PM
Ant-Man
Ant-Man's Avatar
When I did mine I was in a buddy's barn/garage in about 105 degree heat and like 90% humidity... I said screw this I'm getting the saw zaw.
Old 09-24-2018, 09:10 PM
Pete2k_Z28
Pete2k_Z28's Avatar
Sounds familiar, so are you in Florida or Texas?
Old 09-24-2018, 09:13 PM
Pete2k_Z28
Pete2k_Z28's Avatar
Follow up: So I got the charge hose in. I wound up disconnecting the bottom line from the rad so I could get a little more leverage on it, then kind of worked backwards from there. Eventually I found a good medium where the charge hose passed through and the end went naturally into the radiator without stressing it. Also nothing is touching the tensioner etc. I would have posted a tutorial but it's just one of those feel things you just have to do. Thanks for all the replies! Had I gotten to this step earlier in the build I have no doubt I would have just gone Ant-Man's way and installed hoses or AN lines.
To ECS Install - Trans cooler lines?
Quick Reply: ECS Install - Trans cooler lines?
