Who's ready for a easy Aux fuel Pump Kit for the C7??
Former Vendor
We are just about ready to release our C7 Aux Fuel pump kit. Super easy to install. Takes about 3 hours and comes if everything you will need to do a OEM install. It will come with a wire harness and controller and won't break the bank. No need to drop the tank either. Just finished all the controller testing today.
Thanks,
Billy
Thanks,
Billy
Received 1,762 Likes
ttt
Let me know if I have cam with 38% fuel lobe with LT4 inj & pump with A/A TI head unit will I still need meth or can I pull the meth & be good.. Robert
I'm Batman..
Pro Mechanic
Billy, ok, you have my curiosity. How is this different from all the other systems on the market? I assume we are still having to sump the side of the tank, run feed and return lines up the rocker panel and tap into the high side, right?
Assuming there is some sort of better "catch" here MTI is referring to. I am curious as well Ant.
Billy please give me info asap on this I am putting together a all forged motor build now but it will still be about a full month out before it will be done... Robert
Former Vendor
I'm Batman..
Pro Mechanic
Ant
Billy@MTI (10-12-2018)
Former Vendor
Thanks for the info, Billy. So its a returnless system then it looks like since your basically just boosting the pressure through the existing high pressure line running to the front. I like it. About how much is the kit going to run? I may be interested in one and if you guys are interested in giving me a discount I can write up a whole How To guide like all my others on the forum to help everyone with the install.
Ant
I have this system i bought from MTI a few weeks ago, talk about great customer service from Billy and the whole team there. This system is very easy to install, good quality parts and again great customer service.
Billy@MTI (10-15-2018)
I like it. I suppose the stock fuel lines can handle the additional pressure? Assuming it wouldn't have enough to run a port injection setup in parallel?
