Unexpected high revs when downshifting
I have a 19 Z06, M7 with 960 miles on it. On two separate occasions about two weeks apart when I went to downshift the engine starting revving without my foot on the pedal. Has anyone else experienced this and can you offer advice?
Z0HS1CK (10-14-2018)
Definitely sounds like rev match to me.
Btw what year is the car?
2019 you may be right, how do I turn it off?
Also can you disable it to prevent accidental use?
That makes sense I think i may have accidentally hit the on paddle, still dont understand why it would rev so high when downshifting to 2nd or 1st. Wish i could disable.
Received 2,681 Likes
2018 C5 of Year Finalist
You know if Active Rev Match is on if the gear number is illuminated in Amber. If it's off, the gear number is illuminated in White. This is on both your HUD and your gauge cluster.
It also automatically resets to "off" every time you turn off the car, so you need to actively engage it for it to work by clicking either of the steering wheel paddles. I guess the reasoning GM placed the Active Rev Match paddles on the steering wheel vs. a traditional shifter button was to save costs in production by mimicking the A8 paddle shifters.
SuperdadZ06 (10-16-2018)
For the m7 the rev match feature on downshifts probAbly lessens the stress on the drive train by providing optimal revs on downshifts that won’t shock the drive train.
Received 8,928 Likes
When you activate it you don't need to do heel/toe downshifting anymore. The car does it for you. It isn't dangerous and can prevent damage to the car.
Bill
I wish Rev Match would be on at car start up, but since I have had my Z for over 2 years, it is now automatic for me to turn it on as soon as I start the car, love the feature.
Before I got my C7 I thought I'd never use revmatch as I thought that was a gimmick since I knew how to drive stick for many years, but now I turn it on every time because instead of having to concentrate on a smooth shift, it makes the shifts effortlessly smooth, and that throttle blip/bark when slowing down is fantastic whenever it happens.
Didn't you read your owners manual??? I knew about the rev matching and I have an automatic....you know why....because I read the manual. Seriously how can you own a car like this and not read the manual first thing??? Did you know you have a 500 mile break in and then need to change the oil. There is some very important information in that little book, and if you don't read it you may be screwing up a great car.
The following 2 users liked this post by Road machine:
Satanspawn (10-17-2018),
Z0HS1CK (10-15-2018)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
The alternative frequently taken isn't to read when an issue comes up; it's to google a remedy, watch a youtube vid, read someone else's problem matching yours, or come on a forum.
nmerhaut (10-18-2018)
The A8 also has a rev match feature--it automatically blips the throttle on down shifts. Interestingly, as on your M7 the biggest A8 throttle blip occurs on the third to second downshift. Must be a bigger drop in gear ratio than the other shifts. --Bob
