shocks
3rd Gear
shocks
Hi, I have a 1992 Corvette that my daughter and I are working on, not sure if I have a Z-51 suspension on it or not, have not found sticker yet that might tell me and don't know by looking at the suspension. Would it matter if I got the Z-51 shocks all around either way?
Hi, from Abbotsford NZ. Have you checked the RPO codes? Z51 package is code 1BL
Personally I wouldn't mix the Z51 spec shocks with the standard suspension, you would likely find the suspension would be over damped. JMPO someone may chime in who has tried this and can give you a verdict.
I have put the Z51 bilstein shocks on base suspension cars. I like it better than the base shocks. They are a little firmer, but still not harsh. It just feels a little more "planted" to me.
I did this on my '94 and liked it, so I did it again when I got my '95.
The Z51 shocks have the same length fully extended or compressed, except that the fronts can go a little more compressed than the base shocks.
Good luck with you choice.
My 1995 has the FE1 base suspension. I don't know if the spring rates are the same as a 1992 base (or maybe you have the Z51). Anyway my Bilsteins were busted and I replaced them with the standard B6 "performance" Bilsteins that my car had from the factory. The ride is comfortable but more floaty than I wanted... wish I had gone with the B8 Bilsteins. But my life is full of high quality problems so I just enjoy the car. Hope this helps you.
I have the Z51 suspension and had the OEM Bilsteins on my 1996 GrandSport. I recently replaced them with the Ridetech adjustable shocks and I am very happy with them.
Adjust them firm for great handling or soft for a smoother ride. Just another choice which works well!
i put the non-z51 bilsteins (hd i believe) on my base 86 and its too floaty. wish i had put z51 bilsteins on.
Z51 stopped in 91 resumed for 96. 92 -95 went to Z07 which used electric shocks. IDK if there is advantage to z51 vs base Bilsteins replacement shocks, unless car is lowered. Bilstein recommends Z51 shocks for lowered C4s. The replacement shocks are not the same as the OEM. Replacements are multiple year or semi generic. OEM are many times year and model specific or different part numbers for different years and options.
