Alternate oil filter for PF25
LenWoodruff (10-21-2018)
What I don't like about the current AC-Delco filters is that they use a cardboard end cap (just like FRAM). Because of this I like the WIX 51069. Metal end cap and silicone drain back valve.
Received 2,127 Likes
Which makes little sense unless you go 10K miles between oil changes. Also if you have headers a long filter will be much closer to the collector and you'll have hotter oil.
As far as the drain back feature, not an issue with Chevy V8s. Only the ones where the cartridge is on a 45* angle and could empty itself back into the pan.
Not sure if the pf454 is a direct replacement for the pf25, but I've always run a pf35 instead of the pf25. It's the longer truck filter that increases your oil capacity a little bit. If you don't have headers it's a direct replacement. Good luck. P.S. I've also always put an oil filter magnet on my filters. Helps keep any metal in the bottom of the filter rather than circulating in your engine.
Duane
Duane
I have all three in my garage right now.
PF454, PF1218 (same thing, but longer), and WIX 51069.
No sign of a cardboard endcap, but the metal endcap is much thinner on the two AC Delco filters than on the WIX. Perhaps the PF454CL (Classic) has an even thicker metal endcap, but at that price ($10-), just buy the WIX. I'll use up the PF filters I have left, and then switch to WIX.
FWIW, a white Vette in a dark garage does not make the best background for photography.
The following 4 users liked this post by Bikespace:
