Passenger door lock switch?????
Hi,
Discovered that on my 02 Z the passenger door WILL NOT lock with the switch on the passenger door panel.
If I lock it with the drivers door panel switch, it locks
If I lock it with the fob, it locks.
Before I order a switch, I wanted to confirm my arm chair diagnosis... Thoughts???
Thanks in advance.... Pete
Actually that's a great idea. I had the panel off a year ago to deal with a different issue.
Problem solved... swapped switch from my 99. Works like a charm. Easy just pop out switch by lifting front edge.
Thanks!!!
Thanks!!!
