Flapping cargo curtain
Old 10-21-2018, 01:11 PM
rick g
rick g's Avatar
Default Flapping cargo curtain
Is anyone else bothered by the flapping cargo curtain when the tops off? It drives me nuts, in my 05 I velcroed the flap to the cover and then finally cut it off when I bought the storage unit for behind the seats. Now I have an 08 and I’m looking for ideas.
Old 10-21-2018, 01:13 PM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,843 Likes on 1,801 Posts
Slip a metal rod into the seam. This will weigh it down so it doesn't flap around.
Old 10-21-2018, 02:10 PM
FiveVettes
FiveVettes's Avatar
I removed the cargo cover, no problems now.
Old 10-21-2018, 02:21 PM
C6 Snowboarder
C6 Snowboarder's Avatar
I keep my golf bag back there at all times -- never a problem
Old 10-21-2018, 04:16 PM
rick g
rick g's Avatar
Default Good idea
Hadn’t thought of that. I went to Lowes and picked up a 36” steel rod. It should do the trick.
Old 10-21-2018, 04:17 PM
Corvette_Ed
I had the same problem with my C5 coupe. The metal rod took care of it right away.
Old 10-21-2018, 05:09 PM
Wayne88
Wayne88's Avatar
Happens to me too. I usually just raise the passenger window to a certain height where it stops flapping.
Old 10-21-2018, 07:21 PM
carnut08
carnut08's Avatar
I'm not fond of having a metal rod potentially flying around loose in an accident. My solution was a small diameter wooden dowel.
Old 10-21-2018, 07:39 PM
cadyshac
cadyshac's Avatar
And that was heavy enough to work?
Old 10-21-2018, 08:12 PM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
I used the wooden dowel method, drilled a small hole on both ends of the dowel. I then added an eye hook to both ends of the dowel, and attached a retractable ID card holder to the eye bolt. The ID card clip is hooked under the right and left rear speaker plastic trim to hold the shade tight at all times. When the hatch is open, the ID card cord stretches out , and retracts when the hatch is closed. The ID card I used was purchasded at Staples. Here are the pics,
This is what I now have for a rear and top partition. This one does not flap in the wind.
Welker1 (10-21-2018)
Old 10-21-2018, 08:27 PM
Welker1
Welker1's Avatar
Great and ingenious solution; I was just trying to come up with a way to do exactly what you had done in regard to being able to secure the flap yet allow you to open the hatch. Thanks for posting, I will be 'borrowing' your solution.
Old 10-22-2018, 12:23 AM
Cherokee Nation
Cherokee Nation's Avatar
I removed my so i could clean the inside of the glass and never put it back on.....Why do we need it anyway?
Old 10-22-2018, 02:38 AM
SladeX
SladeX's Avatar
I put a metal dowel in there, then I sowed up some elastic straps connected to plastic 3M hook connectors which are hooked into the plastic trim. It still allows easy access to the back without flapping around with the top off. It also keeps anything loose from the back from flying forward either.
Old 10-22-2018, 03:04 AM
C6Whatever
C6Whatever's Avatar
Love your new set up. Did you do it yourself or purchase somewhere? Also does the lid of it touch your targa top when stored in back of car?
Thabks
lisa
Old 10-22-2018, 10:07 AM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Thanks, but I got this idea from another forum member that had done the exact thing and posted it on this great forum. I tried to find the original thread, but couldn't. It had tons of DIY ideas.
Hopefully it will help others as well
Here are the materials used:
1) 3/8" wooden dowel approx 42" in length
2) (2) ID badge holders (Staples)
3) (2) small eye screws
4) a pair of needlenose pliers.
5) Drill with a 1/16" drill bit
Typical ID badge holder, As per the 2nd pic, use a pair of needle nose pliers to spread the metal triangle and remove the plastic snap portion from the ID badge holder.
cadyshac (10-22-2018)
Old 10-22-2018, 10:21 AM
oldcanuck
oldcanuck's Avatar
i just bought a driveway marker rod.It's a plastic rod. Just cut it to size. Lowes and Home depot sell them. About $3.
Old 10-22-2018, 10:24 AM
z06clif
z06clif's Avatar
but will it make the cargo cover sag....due to the weight
I keep my from flapping by velcroing it the the c6 petition I bought from Southern Car Parts. You can alway let the cover down when the top is off
Clif
To Flapping cargo curtain
Old 10-22-2018, 10:29 AM
oldcanuck
oldcanuck's Avatar
Clif
No sag.
Just enough weight to keep it from flapping.
It moves slightly but doesn't flap.
Easy to remove if needed.
Just the right thickness..
Simple and easy
Old 10-22-2018, 11:17 AM
jrose7004
jrose7004's Avatar
Received 1,675 Likes on 1,298 Posts
Mine has the metal rod that holds it down.
Old 10-22-2018, 11:21 AM
4SUMERZ
Race Car Tech
4SUMERZ's Avatar
Lisa,
Thank You. I dit it myself using info received from jost6453 in his FS thread of this type of partition.
The top fits in the space, and the lid does not come in contact with the targa top.
The top lid is a 3/16" plywood glued to a 1" styrofoam board so it does not sag.
Quick Reply: Flapping cargo curtain
