[C2] Midyear Removable Hardtop Interior Color
Received 6,943 Likes
2015 C2 of Year Finalist
The trim and headliner would be red in your case Tom
Tom, I own a red, red 65. The hardtop has red trim and no headliner at present, but a new one in a box to install this winter. It will be red. I also have a 64, black interior and trim and headliner are black. No pictures, but hope that helps.
I would really to to see you car with a Daytona blue top and red headliner. That would be different and very uncommon.
St. Jude Donor '05, '09, '15
Tom
Tom
Sky65 (11-11-2018)
Tom I know for 66-66 coupe headliner they have depressions for sun visors and 63-65 dose not. Hard top headliners might be the same
Received 1,048 Likes
C2 of Year Finalist (appearance mods) 2019
The first picture is wrong, no blue trim on white interior it should be all white. 63 to 65 headliners are the same material and no one sells one with correct material. Original is a very thin layer of soft fiberglass with a very fragile covering ( just like a cheep fiberglass ceiling tile) the reproduction are a hard board product. 66 and 67 hard top are vinyl on foam with paper backing. 66 cp is vinyl on foam with no sunviser recess. 67 cp vinyl on foam with sunviser recess. The 66 and 67 reproductions are very close to the original.
Location: going faster miles an hour...with the radio on in browns mills new jersey
The interior of that car is blue/white (RPO 450) - the blue is "correct".
Tom
Tom
I’ll just state that the 65 repo is not a hard board product.
I’ll also add that your 64 description is probably correct, the liner will not come out without destroying it. Appears to be bonded to the roof panel.
63 to 65 headliners are all made of the same material. They are not bonded to the roof from the factory in anyway. If yours is bonded and is not the thin type it has been replaced.
This is an original 63 to 65 headliner and a reproduction 63 to 65 headliner cp
Reproduction with hardback and material glued right on
Original fiberglass material with paper
and convertible use the same material
