Long tube headers with check engine light
Just purchased a 10 GS with Melrose long tube headers,high flow cats and a Air Raid air intake,check engine light is on and the mechanic tells me that the light is on because the original cats were removed and need to be returned or it needs to be taken to a dyno shop to have the computer fix the problem......any suggestions short of reverting back to OEM
Received 8,806 Likes
Most likely need to have the rear O2 sensors turned off. This is accomplished with a tune along with changing other perimeters so the car is maximizing the additional performance from the added modifications.
Received 1,636 Likes
I would assume the previous owner had a tune done with the mods, but if not, like JabCat and others stated, you definitely need one to tune out the rear 02 sensors and to get the full performance benefits of the mods.
If he has rear cats, doesn't he have rear sensor bungs? Wouldn't the rear sensors be in place? And, if the tune is'was done right, wouldn't he be good to go without having to turn off the rear sensors? Sounds more to me like either the sensors were cut, or there was never a tune done after LT install.
OP, please be sure to let us know what the fix is.
The longtubes remove 2 of the cats (going from 4 to 2) so the O2 sensor placement is also different. With longtubes the rear O2s are turned off because their placement causes the engine light (reading lean/rich I can’t remember) & the tune takes care of correcting those parameters. My guess is the original owner did not get a tune.
Thanks for the clarification, Jab. I have seen LT's with bungs, and without, and header mid-pipes with cats with bungs for rear sensors. Didn't know what the OP had,but figured he at least needs a tune. So, if your headers have bungs for the fore sensors, and you have cats behind them with bungs for the rear, wouldn't you just plug in all the sensors and get a tune?
I put a 90 extension on my uncatted headers and it throws a CEL once in a while. Heard the same thing happens even if you run a HFC so I guess they work?
I'm far from technically fluent on this, mostly what I've researched when I installed my longtubes & exhaust. My understanding is it has to do with the placement of the sensors & the increased exhaust output not being funneled through 4 cats. I'm trying to remember when I removed the stock exhaust, I believe the front O2s were right up next to the manifolds & the rears were just past the first set of cats (don't quote me on that). With the longtubes the fronts get moved way down to the end of the headers where they meet the x-pipe/cats (if you have them) and the rears get moved to after the 2nd set of cats, at least that's where my bungs are on the LG's. I believe, again not an expert, that change in location and the removal of the two front cats causes the rear O2s to foul pretty quick causing the check engine light, and they aren't needed. So most x-pipes come with bolts to close off the rear bungs or you could install the O2s but just have them turned off by your tuner.
Either buy a tuner and tune car or get a proper dyno tune that is required after adding headers, not cheap, probably $500+. Another option, the cheapest, would be to pull your PCM located behind front passenger wheel under the wheel fender. I went this route when I installed my headers myself. From shipping to return to me was about 5 days $149 plus shipping. Cost effective and not as aggressive as a dyno tune, but you will leave a coupe ponies on the table.
https://www.eastcoastsupercharging.c...er-tuning-faqs
Originally Posted by MYCoupe
Just to clarify this for everybody. The front O2 sensors are the ones actually used to measure and adjust the A/F ratio. The rear ones are used to measure the efficiency of the catalytic converters. When switching to LT headers, even with cats in the x-pipe their efficiency is not the same as the OEM ones hence the check engine light comes on. As others have said the solution is to turn them off as they are basically useless.
Former Vendor
St. Jude Donor '12
Corvette Tuner in Tampa
Home of the $295 Calibration with HP Tuners and wideband for stock to bolt ons Corvettes and Camaros to be street race tuned.
Tampa Tuning's in-depth computer process includes low end parking lot driving, cruising at highway speed and WOT.
<<<<<<>>>>>> Check out our Website: www.TampaTuning.com
Reach us at : Tuning@TampaTuning.com
Phil- Owner of Tampa Tuning.
Corvette Camaro Truck Tuner in Tampa Orlando
Supporting Vendor
__________________
www.cspracing.com * Complete Street Performance * CALL US 610-628-1563
And don't forget to Like us on Facebook and follow us on Instagram @completestreet
