Can Bus Support
Old 12-10-2018, 03:42 PM
Jim Bullitt
Jim Bullitt's Avatar
Default Can Bus Support
Does the c6 support the Can Bus circuit ?
Old 12-10-2018, 03:44 PM
Corvette_Ed
Corvette_Ed's Avatar
Received 2,843 Likes on 1,801 Posts
If you are referring to the J1587 or J1939 can bus you can obtain the J1587 data through the OBDII port using a converter. J1939 would not be available.
Old 12-10-2018, 05:08 PM
Jim Bullitt
Want to convert headlights to LED and this is a quote from the LED kit website "
  1. CanBUS Ready -- Work Great with any vehicle CPU that supports CanBUS.
  2. PLUG AND PLAY INSTALLATION -- Easy step-by-step plug and play installation and instructions.
Old 12-10-2018, 05:28 PM
Corvette_Ed
Oh, ok, lol. That's the first time I've ever heard of using that as a power source for LED's. Not sure I'd want to try that myself. In that case, though, someone else will have to answer your question because I don't know if the Corvette has a separate splice pack to tap into the bus.
Old 12-10-2018, 05:37 PM
FAUEE
FAUEE's Avatar
Received 4,447 Likes on 2,803 Posts
That just means it takes existing in the circuit for vehicles that detect if your headlights are out or something like that.
The headlights in a c6 are HID, so youd need to do a good bit of work to replace the bulbs with LEDs in the factory housings, and likely end up with worse performing lights. You're better off switching to the new c7 style lights that way.
If you're trying to do led high beams, those work, you just have to find ones shallow enough to fit the housings, which is hard to do, as bright ones have big fans on the back.
Old 12-10-2018, 06:01 PM
BlindSpot
BlindSpot's Avatar
Received 1,368 Likes on 907 Posts
Yes, correct. Can bus ready lights for any position (turn signals, tail lights, backup, license plate, side marker) basically have the resistor built in so you're not getting reports of burned out bulbs with LED replacements which is a function built into just about every can-bus system out there. Just went through it on one of my British cars.
Old 12-11-2018, 11:17 AM
Jim Bullitt
Thanks, to all for the information.
Old 12-11-2018, 11:31 AM
BlindSpot
BlindSpot's Avatar
No prob - just get the can-bus ones and you'll be fine.
To Can Bus Support
Quick Reply: Can Bus Support
