C7 eLSD fittings <need help>
I had a driver side axle failure that resulted in damage to one of the fittings used to attach the eLSD hose to the differential. After a little research it appears this fitting only comes with the rear differential and cannot be purchaced separately. I’ve been looking for someone who may have one used but without much luck. Any ideas on where I can get this fitting without having to drop 3k on a new differential?
have you tried contacting your local Chevy parts department?
how about taking a look at "racingjunk.com". Did you take a look on eBay? Maybe you could post there.
Received 1,762 Likes
Received 8,928 Likes
Try contacting Gene Culley at CultragFactoryParts. He sometimes finds parts that GM dealer parts guys have trouble finding. It is worth a phone call to him to see if he can get one.
Bill
Bill
I'm Batman..
Pro Mechanic
Here ya go. Appears all four of those dealers were mistaken.
024 - CONNECTOR. Differential Clutch $21.38
Part number: Part Number: 23154582
CONNECTOR,L/SLIP DIFF CLU PIPE(18MM THREAD).
Ant
Ant
https://www.gmpartsdirect.com/oem-pa...ector-23154582
thanks everyone. I ended up getting one from Sam at AMP yesterday but I’m going to follow up and see if this is the right part number I case I have a similar issue in the future.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
This was very frustrating. I went to one local dealer and pointed to the part on the schematic and was told it only came with the diff. I then called two other locals and one out of state. One local game me a part number but when they sent me the picture it was a coolant line fitting. Then I had to deal with the dealer to bleed the eLSD system $280. The same one that told me the fitting wasn’t available.
