Custom sidepipe glasspack Idea
OK so maybe I have too much free time and some basic fabrication tools.
I am adding side headers and pipes to my 68 427. (Dougs headers)
For inserts the quiet ones are way to restrictive and the non restrictive are too load...
So my idea is to fabricate my own, It is a simple glass pack design and should work.
I can use a 2.5 or 3" tube and run it almost the entire length of he pipe.
Thoughts??
Thoughts??
Having [also] spent a stupid amount of time experimenting with various exhaust variations, I'm afraid you will end up with the equivalent of " non restrictive are too load... " - with a probable buffering of some of the high note "raspiness" - as a result of the "packing".
I found I always need some type of baffling to calm the roar down and baffling is much trickier because of the impact on performance. There's much more to it!
Those are my thoughts, for whatever they're worth.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Thoughts??
Thoughts??
Just an item for thought. You could also make a portion of the middle of your insert into an expansion chamber. That would probably help cut/quiet the noise volume pulses (at the 8&4 and 5&7 exhaust valve openings) that are part of life with Chevy engines.
What ever you do, post pictures.
Received 3,220 Likes
Mines a combo- straight pipe and/or muffler. Using electric cut-outs to go between straight unmuffled to full muffler-
I made my own 20" long glasspac type muffler- as from what I have read after 20" the noise reduction is minimal.
perfed SS metal- insinkerator (SS steel) garbage disposal rings hold it together-
I used stainless steel tie wraps- Summit Racing sells them
I wrapped it with exhaust tape- to keep the fiberglass from blowing out-
Here's the cut out design-
Used V-bands to clamp together- and can change out insert if I don't get enough noise reduction
The following 2 users liked this post by Richard454:
Mewn (12-20-2018),
suprspooky (12-12-2018)
I've had the same thought/idea about making my own muffler for sidepipes. My sticking point is the perforated tubing, can't find a good source for 2.5 or 3" 304 SS tubing. I can find flat material but would need a shop to roll it and then weld the seam. Anybody want to share their source?
If there is enough interest, I have a friend with a shop that specializes in laser tube cutting. I will try to get an idea of what he'd charge me to do a small batch of perfed tubes (say 3" x 36" 16g Stainless, $33 on Amazon) using 5mm and 10mm dia. holes and maybe a combo of those sizes.
Richard, I love the electric baffle idea (I've been torn between reasonable sound and minimal HP loss). The quiet Side Pipe Hookers kill power when you are moving enough air to support 560ish crank HP and the Hooker high flows are almost painful (I know,I'm getting soft). I will be using part of your idea on my Hooker Side Pipes (I needed one more Winter project )
I can stop them somewhere in-between. I should have my engine up and running again in the next few weeks- and hopefully will do what I want them to. I didn't save the receipts for all the stainless I bought..,As I don't want to know!!!
https://www.ebay.com/sch/m.html?_ssn...rated&_sacat=0
http://www.ebaystores.com/Myriad-Exh..._sid=131329888
