Removing stock mufflers
I am going to install some Borlas on my 08 Z. I plan on doing it on jack stands.
Has anyone done it? I did it on my c5 Z. It was a challenge to get it up high enough.
Is it similar to a c5? Any other issues I need to be concerned with?
thank
thank
Same...get it up on stands as high as you can. Might need to un-mount the rear sway and let is hang from end links to get mufflers out...but many have done it this way.
Received 3,088 Likes
Front down low, rear high, I had to drop my rear cradle a bit as well.
And patience.
Not everyone cares for these, but this is what is on my 5 ton jackstands using the slots where the lifting pucks would go.
And patience.
No need to drop the rear cradle, but as mentioned you will have to drop the rear splash pan and sway bar, especially for the right (passenger) side. The left side comes out pretty easily but you will need to be patient and manipulate/twist the right side. But be careful as there is a electrical connector on the transmission (reverse lock out IIRC) that could be damaged if you twist it too much. Good luck.
Done it many times.... on jackstands ìts hard to get high enough to get the pass side out. Takes 10 min to drop the cradle a little and everything comes right out. Swaybar has to go as well
