How much brake pad do I have?
Old 01-15-2019, 05:54 PM
sautan
sautan's Avatar
Hi All. Prior to this, I never checked brake pad or have any knowledge but rely on dealer. Since I fall in love with tracking the car, I better start learning.
My car is Z07 equip with CCB. Please refer to the photo. How much brake pad I have left? A or B? I assume it's A but I cannot be sure. I check on my other car, the pad is all same color but this one has light brown and then darker color to the metal.
Can I run another one or two track day?
Now, total about 3,400 miles since new.
Anyone have video link to "How to change brake pad on the C7 with CCB"? I have googled and youtubed but mostly C6 or C7 without CCB.
Thank you.
Hi All. I am sorry if I asked stupid question but hope someone can advise. Thank you.
Old 01-16-2019, 07:29 AM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
B in theory.
But if you are tracking the car then id be replacing them at A.
sautan (01-16-2019)
Old 01-16-2019, 08:11 AM
poughkeepsie
poughkeepsie's Avatar
And change them earlier than later. You don't want to damage that rotor. They are very expensive
sautan (01-16-2019)
Old 01-16-2019, 01:23 PM
sautan
sautan's Avatar
Originally Posted by PatternDayTrader
B in theory.
Thank you. As of now, it has about 4mm on the light brown area and total about 7mm. I guess I should be good for one more track day.
Old 01-16-2019, 07:51 PM
AZav8r
AZav8r's Avatar
For a true measure of remaining material, measure between the disc surface and the metal wear indicator tab on the pad assembly.
sautan (01-16-2019)
Old 01-16-2019, 08:09 PM
mjcourt
mjcourt's Avatar
I don't have carbon/ceramics, but I believe I've heard that their pads don't have an indicator tab. Steel tabs rubbing on ceramic rotors wouldn't be a good combination.
sautan (01-16-2019)
Old 01-16-2019, 08:14 PM
sautan
sautan's Avatar
That is correct, no indicator. It's all by visual.
Old 01-16-2019, 08:26 PM
AZav8r
AZav8r's Avatar
Ah ha....
rsvette12
rsvette12's Avatar
Thank you.
Heres an excellent video on changing pads
To How much brake pad do I have?
Quick Reply: How much brake pad do I have?
