C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Mid grade fuel rail upgrade?
Old 01-20-2019, 09:31 PM
DonC6LS3
DonC6LS3's Avatar
Default Mid grade fuel rail upgrade?
I accidentally yanked my Schrader valve fitting completely out of my fuel rail on my LS 3C6. Rather than buying a used set of factory fuel rails I am wondering what would be a decent upgrade. Does anyone have some input? I do have a 416 stroker, TFS heads, cam, 3.42 gears, and A 3000 stall converter.
I have stock fuel pump, stock fuel lines, and stock fuel injectors I’m thinking that if I get a little bit larger capacity fuel rails that might help with the nitrous hit
Old 01-20-2019, 10:48 PM
realcanuk
realcanuk's Avatar
St. Jude Donor '13
Holley work fine.
Old 01-21-2019, 08:18 AM
Ant-Man
Ant-Man's Avatar
Fasster on ebay, dude makes his stuff in Ohio and had fuel rail kits for like 130$ and is a ptfe line
To Mid grade fuel rail upgrade?
Quick Reply: Mid grade fuel rail upgrade?
