GS fronts on rear?
Old 01-22-2019, 11:24 AM
smd001
smd001's Avatar
Default GS fronts on rear?
Can I use my GS front wheels on the rear? I would like to use them for drag radials.
Old 01-22-2019, 12:05 PM
C6 Snowboarder
C6 Snowboarder's Avatar
This will go well...
Old 01-22-2019, 12:31 PM
mcandrew67
mcandrew67's Avatar
Received 1,013 Likes on 599 Posts
2016 Corvette of Year
2015 C6 of Year Finalist
you can, they fit, about 2" inside the wheel well, would look stupid, but you probably don't care about that.
Old 01-22-2019, 12:37 PM
Seadawg
Seadawg's Avatar
You will probably cause active handling issues if you are not careful and keep close to the same front/rear ratios that you currently have.
Old 01-22-2019, 07:46 PM
buckmeister2
buckmeister2's Avatar
Received 1,206 Likes on 824 Posts
your front tires are 2" narrower, and 1" shorter than your rears. You seem to be ignoring the importance of contact surface. While a narrower tire has a smaller contact surface, so does a shorter tire. If you want to improve traction, get drag radials for the rear wheels. The wider tread and greater diameter have a better contact surface.
Possibly, you can't find drag radials to fit the rears. If that is the case, open that question up to the forum. I certainly would not go to a narrower and shorter tire expecting better traction.
Old 01-22-2019, 11:08 PM
jbc1995fb
jbc1995fb's Avatar
Received 1,385 Likes on 897 Posts
would you use the stock size front tire on that wheel? If not, what tire do you plan on using? I know people use 15” or 16” wheels and put taller tires on the rear for traction. Is that what you’re trying to do by using 18” wheels?
Old 01-23-2019, 11:02 AM
smd001
smd001's Avatar
I guess I should have been more clear. My intention was to use the 18s for drag radials only. Not for any other reason.
Most likely ill just sell the gs wheels and tires and buy a nice drag pack.
Thanks for the inputs.
To GS fronts on rear?
Quick Reply: GS fronts on rear?
