[C2] 67 L36 vs L68
Received 6,943 Likes
2015 C2 of Year Finalist
Unless the dealer swapped out the block it would remain the same. No one will know if any dealer did that but it’s a simple swap. Just the intake, carbs, air cleaner, and other small parts.
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Welcome to the forum!
Received 2,341 Likes
The dealer would not change the stamp on the block, regardless of what intake assembly was installed after they took delivery of the car.
Dealers made many parts swap, for paying customers, but documentation from the dealer is more important to a collector than the physical parts (for example, a Yenko invoice or similar document showing the change).
I would expect an L36 block with a 6-pack would receive flight judging point deductions (if a TF restoration is a goal, otherwise it looks cool and if it works well the 6-pack can deliver good fuel economy).
Just asking because I have seen a window sticker (reproduction?) that showed an L36 in the top part of the RPO's and at the bottom a L68 conversion that listed for about $104.00 extra. I guess the block should still have T----IC stamp on it. ??
That is how GM billed the L68.
As stated above the window sticker would show both, it is not a conversion, the block would be stamped by the factory JC.
