C4 Parts for Sale/Wanted C4 Corvette Performance Parts, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements, OEM, Aftermarket
FS: from 86 coupe parted out : interior and electrical
Old 03-23-2019, 10:53 AM
amy FL
amy FL's Avatar
Default from 86 coupe parted out : interior and electrical
good working condition parts. Off a 86 coupé.
will ship 48 lower states
payment cashiers check, usps money order, chase quick pay or square cash.me. No paypal.
front end
rear end
underhood and drivetrain
bumper covers
ABS pump 80
accelerometer $15
3-row relay bracket $10
spkr grill $12, front, 2 available
spkr grill, non-bose systems, dash, 2 avail, $10 ea
VATS $40, working.
chime module $25
multifunction lever $40
power lock actuator $10
kick panel $15 tan
halo light complete $20, both sides available
spark / knock module $40
seat switches with harness, uncut $20
Header trim (horizontal, inside, top of windshield, between Pillar Posts) $60
Courtesy Light in Door $30
door inside hardware : rods, levers, small fasteners, set for $40
power window motor $20
window regulator, late C4 style, pass side $40
parking brake assembly ,$30
Steering wheel, leather cover needs replaced, $60
Complete telescopic steering column, for auto trans, disassembled.needs new bearing. Includes rod and ignition switch plus hi/lo beam switch $100
DIC lens. left lower pictogram id for Overdrive. $40
throttle pedal complete assembly, $30
set of seatbelts, tan, $100
belt receptors, black, $ 20 pair
odometer 197000 miles, $50
cargo shade $30
breadbox $30
hood open lever $20
many pigtails and harness, one intact rear harness serving antenna, hatch, tail lights, fuel pump,...
Also available, original screws, clips, rods, and bolts. Ask whatever gizmo you need from those boxes.
the digital dash HAS BEEN SOLD already
thks for viewing
Old 03-23-2019, 11:25 AM
ghoastrider1
ghoastrider1's Avatar
saddle (tan) console cover in decent shape? door panels? heater/as control thingy in the dash? Is the rearview mirror clear? ? l live in Avon, Indiana. Its next to Indianapolis..45123, thanks. Oh is that the heaer core that you listed? And what parts contained I the parking brake offer? fuel pump and fuel level good? I too have an 86. headlight motors complete assy.? do window motors? There is one just listed local for parts so my wants/needs will change.
Old 03-23-2019, 01:07 PM
amy FL
amy FL's Avatar
Hello, Rider
maany answers here :
what is NOT available
(tan) console cover in decent shape ; door panels ; heater/as control thingy in the dash ; rearview mirror ;
now some positive :
is that the heaer core that you listed? yes
parts contained I the parking brake offer ? full lever assembly
fuel pump and fuel level good ? risks are pump is corroded. I Did not remove the plunger from tank. level meter is usually recoverable with gently sanding. Safer to buy a new pump as you know what happens when this thing dies on you.
headlight motors complete assy.? motors are here and good but when unbolting the 13 mm it snapped on both.pics.
I have the lower and upper cover for passenger side $20 ea / $30 both
do window motors? I have one complete window mechanism pass side, late version (not the ribbon type)
tell me if you need more parts, I did not process the front of car nor engine chapter.
Old 03-24-2019, 08:50 PM
Jsonova99
Jsonova99's Avatar
Do you by any chance have a half decent rear carpet piece in tan? The center piece that covers the cargo doors and the rear bulkhead?
Old 03-25-2019, 01:03 AM
amy FL
amy FL's Avatar
no, sorry, not in store. thks.
Old 03-29-2019, 06:33 PM
amy FL
amy FL's Avatar
ttt
Old 03-30-2019, 01:40 PM
RockyL32
RockyL32's Avatar
Location: If your not the lead dog the view never changes Boise, Id
I need a fog light switch if you have still have it.
Old 03-30-2019, 09:47 PM
amy FL
amy FL's Avatar
gone already...
have a good day
Old 03-31-2019, 06:23 PM
auburn2
auburn2's Avatar
Do you have the black center trim (the part that goes around the radio and vents, and the black trim that goes around the instrument panel?
Old 04-01-2019, 07:40 AM
amy FL
amy FL's Avatar
hello,
sold last week
regards
Old 04-01-2019, 07:52 AM
amy FL
amy FL's Avatar
ttt
Old 04-05-2019, 09:05 PM
amy FL
amy FL's Avatar
ttt
Old 04-11-2019, 02:51 PM
amy FL
amy FL's Avatar
ttt
Old 04-14-2019, 03:54 PM
rnoswal
rnoswal's Avatar
Looking for the mirror adjuster switch and at least the mirror motors, both sides, mirror and motor assembly. I don't need the shells but I didn't see any of these items on your list.
Thanks
Russ
Old 04-15-2019, 10:37 AM
amy FL
amy FL's Avatar
here is what I have in the outside mirrors dept.
2 passenger glasses with plate. One has new glass with bullseye to avoid dead angle. other has chip in one corner (how do people do this ? )
mirror surfaces are very good ; pics don't do justice to this here.
motors tested to work good. a vented model other not.
one trunnion, a pigtail, two plastic plates for mirror shells.
I also have the pass and drv shells as well as the mounting mracket for motors inside the shell.
other harness parts available as well.
no joystick.
Old 04-15-2019, 01:50 PM
rnoswal
rnoswal's Avatar
Well Amy, it all looks like the stuff I need to make mine work. I noticed my pass side was heated like I noticed on yours but something I never considered until I noticed yours. That doesn't seem to matter too much here in the south . I don't really need the inner hardware for mirror motor mounts but curious about the backing plates for the mirrors. Do they just pop off or glued? Will have to look closer at mine. And yeah, how do people chip these things!
So, let me know what you want for them please. My address, for shipping cost look up is;
Russ Lawson
1284 Schex Dr
Bossier City , Louisiana
71112
Thanks
Old 04-18-2019, 07:00 PM
amy FL
amy FL's Avatar
pm sent
To from 86 coupe parted out : interior and electrical
Quick Reply: FS: from 86 coupe parted out : interior and electrical
