Wheel Bearings - Which is the best ?
Old Jun 14, 2019 | 04:57 PM
Sounds's Avatar
Sounds
Default Wheel Bearings - Which is the best ?
I've been looking to get new wheel bearings for front and rear, For my C5. ''Car sounds like it's riding on a train track" I seen several to buy but which is the better .They all say about the same , the difference is price. I seen some from $56 to $400. I just want to replace and get a good ride. Can any one help with this topic : salute:
Popular Reply
Jun 15, 2019, 03:54 PM
acrace's Avatar
acrace
If you want “the best” and your budget can afford it, the SKF X-Tracker (also known as the HD or road race hub) is by far the most durable. Cheapest is through Phoenix Performance - look at the autox for sale sub forum. Also available through Van Steel - image has the p/n shown.
Tighter budget? Regular SKF or Timken.
Old Jun 14, 2019 | 07:46 PM
ArtClassShank's Avatar
ArtClassShank
Timken
Old Jun 14, 2019 | 08:21 PM
feeder82's Avatar
feeder82
this is one of those parts if you don't buy quality, you will be replacing again soon
Old Jun 14, 2019 | 09:06 PM
StingrayRebel's Avatar
StingrayRebel
if you search around you might be able to find some nos gm bearings when they were still made in the u.s.a.
Old Jun 15, 2019 | 09:03 AM
Ramets's Avatar
Ramets
Careful, there's a lot of Chinese knockoffs out there. I ran into that problem with my diesel motorhome. Had the fronts replaced, 6mos. later they needed to be replaced again. The guy who did it the 2nd time told me to be sure you get bearings made in the USA.
Old Jun 15, 2019 | 12:40 PM
fuggles's Avatar
fuggles
The Timken bearings from South Korea are high quality. I got mine from Zip.
Old Jun 15, 2019 | 03:54 PM
acrace's Avatar
acrace
Old Jun 15, 2019 | 10:23 PM
Sounds's Avatar
Sounds
That's perfect ! I'm looking for just above good but not the most costly, I need quality . Great info Thanks
Old Jun 17, 2019 | 06:02 AM
wscott62893's Avatar
wscott62893
I’ve had good luck with MOOG wheel bearing assemblies from Autozone. I’m running them on all 4 corners. I installed a Timken from RockAuto at the start of the summer and it lasted 50 miles...but I’m pretty sure it was a junk part from the beginning (typical RockAuto issue). So I won’t say Timken bearings are bad. The MOOG bearings are really well made and have survived numerous AutoX events so far. They also come with a 3 year warranty which is a plus. I paid approximately $170 per bearing/assembly
Old Jun 17, 2019 | 08:41 AM
1996Z15's Avatar
1996Z15
On average at what point, mileage wise, do you need to replace the rear hubs / bearings? My 2002 Z06 has just over 68,000 miles on it and I am wondering when I should expect to need to replace mine.
Old Jun 17, 2019 | 09:01 AM
wscott62893
I replaced my originals at 130k and they weren’t even making noise yet...I just did it out of “good practice” because I had the entire rear end apart for new ball joints, poly control arm bushings, Bilstein Shocks, tie rods, half shafts, etc.
Old Jun 17, 2019 | 09:37 AM
ArtClassShank
One of my fronts started making noise at about 82K.
It's very driving style dependent. If you have sticky tires on your car and you drive the hell out of it, they're going to fail sooner then if you just highway cruise most of the time.
Old Jun 17, 2019 | 11:32 AM
smitty2919's Avatar
smitty2919
SKF X-Tracker
Do it once, do it right and never touch the bearing again lol
Old Jun 17, 2019 | 01:42 PM
gimp's Avatar
gimp
Who's the reliable forum vendor for the X-Tracker kit in 2019?
Old Jun 18, 2019 | 05:38 AM
awches's Avatar
awches
My left rear bearing started making noise at about 120,000 miles so replace both with timken's from Rock Auto. A little later replace the fronts with Moog's I think. Had been having a little front vibration at 80 mph area the a few balance jobs could not get rid of. The front end bearing change fix it.
Old Jun 18, 2019 | 10:04 AM
50thz06's Avatar
50thz06
Mine were noise-free at 55,000 but discovered movement in left rear wheel during an alignment attempt and replaced front and rear bearings with SKF. Hardly any miles since then, so no recommendations, jury still out.
Old Jun 18, 2019 | 11:59 AM
smitty2919's Avatar
smitty2919
Sam Strano
Danny Popp
I'm sure places like Ridetech or Vansteel can get them too.
To Wheel Bearings - Which is the best ?
Old Jun 18, 2019 | 02:40 PM
gimp's Avatar
gimp
Thanks for the info.
Old May 28, 2024 | 04:47 AM
Z06Princess's Avatar
Z06Princess
3rd Gear
you definitely should look into getting new bearings..
Old May 28, 2024 | 06:06 AM
USAZR1's Avatar
USAZR1
Well, since you revived this five year old thread, the OP has hopefully replaced his, by now.
