C8 General Discussion The place to discuss the next generation of Corvette.
How to watch the C8 reveal on your TV using a Windows laptop
Old 07-15-2019, 06:02 PM
Quinten33
Quinten33's Avatar
Default How to watch the C8 reveal on your TV using a Windows laptop
I saw someone ask about this in a different thread, so for those of you who would like to watch the long-awaited reveal of the C8 Corvette on your TV, here are instructions and solutions to issues you may encounter. I am unsure if this will work with an Apple laptop or Chromebook, but it will work with any laptop that uses Windows.
Materials needed:
TV
Laptop
HDMI cable
Step 1: Connect the HDMI cable to your laptop and open your laptop
Step 2: Connect the other end of the cable to your TV, using an HDMI port located in the back of the TV or on the side.
Step 3: Using your TV remote or the Input button on the TV, change the input channel to the name of the HDMI port which you plugged the cord into. If you are unsure of which HDMI port you plugged it into, make sure that the screen of your laptop is on and flip input channels until the laptop screen is displayed on you TV.
Step 4: Your laptop screen should now be displayed on your TV screen. You can click the following link to open the Chevy Pressroom website, where the reveal will be streaming live: https://media.chevrolet.com/nextgenCorvette The day of the reveal, there broadcast should appear on the website in the same way that the other videos appear. In order to make the broadcast full-screen, click the square icon in the bottom right corner of the box in which the broadcast is displayed.
Troubleshooting
If your laptop screen is blurry or not full-screen on your TV, go to the settings on your computer and find the section that includes "Display"(on Windows 10, this should be under the System section of the settings). After selection that section, You should see a sub-section titled Resolution with a drop-down menu. Select the option with the largest numbers(such as 1920x1080) and check the image displayed on your TV screen. If it is still blurry, try other resolutions options until you find one that works.
Step 5 (optional): If you would like to keep your laptop screen off during the live stream, you can click both the Windows key and and P key at the same time. This will bring up a menu on your screen with multiple display options. There should be an option called "Second screen only". Click on it to disable your laptop screen. Note that your laptop's mouse/touchpad and keyboard will still work while the laptop screen is off. You can re-activate your laptop screen by pressing the Windows key and P key again and selecting the "Duplicate" option.
Troubleshooting
If the letters and/or icons on your laptop screen are too small when displayed only on your TV, use the instructions in step 5 to re-activate your laptop screen. Now go into the display settings mentioned in the previous troubleshooting steps and find the sub-section titled "Scale and Layout". In the drop-down menu of this section, select an option higher than the default option(I'm using 175%). Now press the Windows key and P key at the same time, then select the "Second screen only" option again. The letters and icons displayed on your TV screen should now be larger.
IMPORTANT THINGS
IN ORDER TO RESTORE YOUR LAPTOP'S DISPLAY SETTINGS AFTER WATCHING THE REVEAL, YOU MUST GO BACK TO THE SETTING MENUS I HAVE MENTIONED AND REVERT ANYTHING YOU CHANGED TO ITS DEFAULT OPTION.
YOUR LAPTOP WILL STILL BE USING ITS OWN POWER DURING THIS, SO YOU MIGHT WANT TO MAKE SURE THAT IT IS EITHER FULLY CHARGED OR CHARGING WHEN USING IT TO STREAM THE REVEAL.
The following 10 users liked this post by Quinten33:
68roadster (07-15-2019), crabman (07-16-2019), elegant (07-15-2019), John T (07-15-2019), Mickeyrx70 (07-17-2019), RapidC84B (07-15-2019), ShagVette (07-15-2019), Shaka (07-16-2019), Weasel (07-17-2019), Z06_Ruff (07-15-2019) and 5 others liked this post. (Show less...)
Popular Reply
07-15-2019, 07:40 PM
davidwp97
davidwp97's Avatar
I'm old and will be in bed by 10pm Eastern, let me know how the side vent looks.
Old 07-15-2019, 06:03 PM
Aerovette
Aerovette's Avatar
What if her husband is still alive?
The following 7 users liked this post by Aerovette:
Easy Rhino (07-15-2019), Jerradl1987 (07-15-2019), kingpin111 (07-18-2019), Lacquer (07-15-2019), mattkilla2015 (07-15-2019), Quinten33 (07-15-2019), tail_lights (07-15-2019) and 2 others liked this post. (Show less...)
Old 07-15-2019, 06:04 PM
Quinten33
Quinten33's Avatar
What?
Old 07-15-2019, 06:14 PM
DCDano
DCDano's Avatar
Originally Posted by Quinten33
What?
Typo in the thread title.
Old 07-15-2019, 06:22 PM
LuisZ51
LuisZ51's Avatar
What's HDMI?!
The following 8 users liked this post by LuisZ51:
firstvettesoon (07-15-2019), Malum1 (07-15-2019), marinablu67 (07-18-2019), Michael A (07-16-2019), Philr56 (07-16-2019), Rinaldo Catria (07-16-2019), tail_lights (07-15-2019), Weasel (07-17-2019) and 3 others liked this post. (Show less...)
Old 07-15-2019, 06:36 PM
TheGadgetGuru
Support Corvetteforum!
TheGadgetGuru's Avatar
Or, if you have an iPad and a computer, simply watch the reveal on the iPad and stay tuned on this forum on your computer to read the reactions as they occur.
SouthernSon (07-17-2019)
Old 07-15-2019, 06:45 PM
Quinten33
Quinten33's Avatar
My bad
Can I fix it or do I have to repost?
Old 07-15-2019, 06:52 PM
mschuyler
mschuyler's Avatar
Received 3,818 Likes on 1,614 Posts
Or just watch it on your laptop.
Speednet (07-15-2019)
Old 07-15-2019, 06:53 PM
firstvettesoon
firstvettesoon's Avatar
Received 1,906 Likes on 750 Posts
Chrome cast
The following 5 users liked this post by firstvettesoon:
Houston Z33 (07-17-2019), jdvann (07-16-2019), mattkilla2015 (07-17-2019), Quinten33 (07-15-2019), Sin City (07-16-2019)
Old 07-15-2019, 06:57 PM
DevonK
DevonK's Avatar
Fire stick or Apple TV
The following 3 users liked this post by DevonK:
Houston Z33 (07-17-2019), Quinten33 (07-15-2019), Sin City (07-16-2019)
Old 07-15-2019, 07:11 PM
Quinten33
Quinten33's Avatar
Yes, the Firestick, Chromecast, and Apple TV are all better ways to watch the reveal on your TV than using a laptop and an HDMI Cable. I’ll actually be watching it using an Xbox One X. But not everyone on this forum has one of those devices or is tech-savvy, so I thought that that I should post these instructions. Someone is bound to need them or use them.
The following 5 users liked this post by Quinten33:
$Bill (07-17-2019), bcmarly (07-16-2019), Houston Z33 (07-17-2019), mattkilla2015 (07-17-2019), nrbc7 (07-17-2019)
ToddC7
ToddC7's Avatar
XBOX in 4K. Easiest solution.
The following 2 users liked this post by ToddC7:
Philr56 (07-16-2019), Weasel (07-17-2019)
Old 07-15-2019, 07:20 PM
Speednet
Speednet's Avatar
Originally Posted by firstvettesoon
Chrome cast
This is the easiest right here. Most people use Chrome for a web browser, and Chromecast makes it a one-click deal to broadcast content from your browser (Chrome) to your TV.
Old 07-15-2019, 07:28 PM
Pisswilly
Pisswilly's Avatar
What’s Windows?
CheezMoe (07-15-2019)
Old 07-15-2019, 07:39 PM
pietro c7
pietro c7's Avatar
Received 1,157 Likes on 650 Posts
Could I do this with a PlayStation ?
Old 07-15-2019, 07:40 PM
davidwp97
davidwp97's Avatar
The following 10 users liked this post by davidwp97:
B747VET (07-17-2019), Co-Vette (07-17-2019), Corgidog1 (07-16-2019), firstvettesoon (07-15-2019), mattkilla2015 (07-17-2019), ojm (07-15-2019), PANHANDLE96CE (07-17-2019), trooper (07-17-2019), Weasel (07-17-2019), Z51VetteFan (07-16-2019) and 5 others liked this post. (Show less...)
Old 07-15-2019, 07:47 PM
Kevin Parent
Kevin Parent's Avatar
EFF them. 10:30PM EST? I see they don't care about the other coast and in between.
To How to watch the C8 reveal on your TV using a Windows laptop
Old 07-15-2019, 08:00 PM
Quinten33
Quinten33's Avatar
The Playstation 4 has a browser that doesn’t support flash so it might not work to stream the reveal. You can try accessing the Chevy website on there and see if the videos will pop up. If they do, it should work for the stream.
Old 07-15-2019, 08:12 PM
pietro c7
pietro c7's Avatar
Thank you Quinten33
Old 07-15-2019, 08:20 PM
Z06_Ruff
Z06_Ruff's Avatar
St. Jude Donor '19
Thanks for the info. I'll be tuning in.
Quick Reply: How to watch the C8 reveal on your TV using a Windows laptop
