1967 327/300hp engine suffix
Old Nov 6, 2019 | 12:43 AM
STLnative's Avatar
STLnative
1st Gear
Default 1967 327/300hp engine suffix
I’m looking at a 67. The 327 engine stamp VIN looks correct. My question is the suffix. The stamp reads V0202HE. The HE from what I’ve read is 1965, but I’ve also read GM reused suffixes. Maybe I’m being overly precautionary but I want to make sure this is correct. The car is pretty original, but I just want to make sure. Any help is appreciated! Car was built March 8, 1967 according to the plate. (G08)
Old Nov 6, 2019 | 01:58 AM
68hemi's Avatar
68hemi
C1 of Year Finalist (performance mods) 2019
HE is the correct suffix for a 1967 300 h.p.with 4 speed but unfortunately the beginning character for the stamp you show should be “F.”
Old Nov 6, 2019 | 02:53 AM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
no, V is correct for 1967 you are thinking of 63 to 66.
Old Nov 6, 2019 | 04:39 AM
65GGvert's Avatar
65GGvert
V0202HE
V is correct.
0202 is Feb 2nd
HE is correct for 327- 300hp, 4spd
G08 is FEB 8th
All lines up so far.
Old Nov 6, 2019 | 06:40 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
One advantage ot the lower HP engines is that there is less incentive to "fake" them, so far your numbers line up...
Old Nov 6, 2019 | 10:12 AM
John BX NY's Avatar
John BX NY
Post a pic of the pad and plenty of expert opinions will follow !!
Old Nov 6, 2019 | 10:43 AM
65GGvert's Avatar
65GGvert
​​​​​I'll give you my opinion before you post it. Don't.
Old Nov 6, 2019 | 01:03 PM
68hemi's Avatar
68hemi
You are correct, my mistake.
Old Jan 21, 2024 | 10:19 AM
Hansoplast's Avatar
Hansoplast
6th Gear
Hello. Looking for numbers on my 1961 Corvette. Understand that it is not an original 283 engine but a 327. On engine castingnumber 3782870 and J112 so oktober 1962. Number on the head are given data J42 so 62-oct-4. Ignition has 2K3 so 62-nov-03. And the Carter carburator J2 so 1962. On the engine block right front block is stamped F I0 I3 RB. I understand from your forum that F= Flint I0 = October I3 = 13th. But what means RB. Reading the forum for many hours but I cannot find the info. Any help?
Old Jan 21, 2024 | 10:31 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
RB is a 327/300 manual trans with a 4 barrel carb from a 62-63 full size car.
starting a new thread would have been better for more results
Old Jan 21, 2024 | 10:50 AM
Hansoplast's Avatar
Hansoplast
6th Gear
Thanx for reply. I am new to the forum and not familiar with the set up. But I will learn by doing.
How to find the production year of the block? The ancilliars are all 62.
Old Jan 21, 2024 | 12:03 PM
Nowhere Man
On the passenger side of the block on the rear flange where the bellhousing or auto bolts too is the casting date
Old Jan 21, 2024 | 01:53 PM
Hansoplast's Avatar
Hansoplast
6th Gear
I am making it unnecesarily difficult. Had given the date already; J112.
So I have a Corvette C1 birthday November 1960, model C1 model 1961 and engine october 1962.
Up to the next step before starting restoration. The official importing/ registration by the governement.
wish me luck.
Thanks for help.
Old Feb 1, 2025 | 12:25 PM
OldKarz's Avatar
OldKarz
From: On the bank of the Columbia River..... Washington State
On first blush I think it looks good, but agree that I would sure like to see pics of a few others that went across the line close to same time....
Old Jun 8, 2026 | 05:36 PM
GavinDouglas11's Avatar
GavinDouglas11
1st Gear
Default Help me decode 327 hi/po
so i bought a 72 c10 with what i was told was a 350 /t350 .turns out to be a 327 from 1967 having trouble figuring it out
block says 3892657 witch comes back as 302 327 350
front code is 7N194630 VO3I7MS
HEAD I THINK IS ORIGINAL SAYS 3890462 FOR CAMEL HUMP HEAD DATED 67 CANT FIND THE MS PART OF THE SUFFIX
Old Jun 8, 2026 | 06:05 PM
Nowhere Man
It's from a Camaro
Old Jun 8, 2026 | 06:12 PM
leif.anderson93's Avatar
leif.anderson93
The partial VIN on the front pad tells you the motor was originally installed in a 1967 vehicle. The date stamp tells you it is a Flint block, assembled on March 17. The MS tells you that it was a 350 cu. in. / 295 hp, with a 4 barrel carburetor and manual transmission installed in a Camaro.
Old Jun 8, 2026 | 06:19 PM
Nowhere Man
Originally Posted by leif.anderson93
The partial VIN on the front pad tells you the motor was originally installed in a 1967 vehicle. The date stamp tells you it is a Flint block, assembled on March 17. The MS tells you that it was a 350 cu. in. / 295 hp, with a 4 barrel carburetor and manual transmission installed in, either, a Camaro or Nova.
a Nova would have its own unique block. And I don't believe Novas where made at Norwood Ohio
Old Jun 9, 2026 | 03:04 AM
L78's Avatar
L78
Also,
For the 1967 model year, the 350 was exclusive to the Camaro SS350. Nova, Truck, Corvette, full-size and Chevelles did not get the 350 engines until the 1968 model year.
To 1967 327/300hp engine suffix
