Viking coil over kit
Old Jul 10, 2020 | 09:47 AM
White 68's Avatar
White 68
Default Viking coil over kit
Has anyone here used these Viking coil overs ? I was looking at the complete kit listed for my 68 big block. Thanks for any comments or advise.
https://www.fabquest.com/viking-shoc...onversion.html
Old Jul 10, 2020 | 10:15 AM
gkull's Avatar
gkull
That is one of the cheaper kits that I have ever seen. Personally I don't think that 450# springs a stiff enough and cause excessive front end dive when you jump on the brakes. But to each his own! I've been very happy with my QA-1 dual adjust kit
Old Jul 10, 2020 | 07:31 PM
Corvettedave02's Avatar
Corvettedave02
C3. 427, 4-link, c7 z06
Aren’t the stock springs 400 lbs? 450 should be a nice upgrade on stiffness. I was looking at that kit too but went in another direction for drag racing.
Old Jul 10, 2020 | 08:25 PM
bazza77's Avatar
bazza77
I have them on my 69 , frame is rolling only . They bolted straight in , no problems . I got the bearings and the tool kit as well.
Old Jul 10, 2020 | 08:48 PM
White 68's Avatar
White 68
Thats my plan ! want to be able to adjust the ride height. Bilstein shocks alone would be 400-500 so this kits a bargain
Old Jul 10, 2020 | 08:50 PM
RU7376vettes's Avatar
RU7376vettes
I put Viking coilers on the front of my 73 convertible and used their double acting shocks on the rear with 9 leaf stock spring modified by Eaton Detroit. I put Global West tubar A Arms on the front when I installed the coil overs. I have nothing but praise for Viking, good quality and excellent technical assistance. The difference in the way my car handles now is amazing. It is like a totally different car. There was a local speed shop near me that offered a 10% discount on the Viking items. (Beefcake Racing) If you look at the history behind Viking, the principles came from QA-1. I have Ridetech coilovers, tubular A arms plus their 4 link on my 55 Chevrolet. It was a lot more than the Viking and Viking has separate adjustment on compression and rebound. As for the spring size, I went with what they recommended. My car is now 26 1/2" in the front and 27" in the rear. It used to be a challenge at high speeds and now stays flat and straight.
Old Jul 11, 2020 | 10:11 PM
White 68's Avatar
White 68
That’s good to hear ! I also read the owners came from QA 1
Old Jul 11, 2020 | 10:16 PM
White 68's Avatar
White 68
Old Sep 28, 2021 | 02:58 PM
trans am kev's Avatar
trans am kev
the stance looks great thinking of buying the viking or qa1 which spring rate did you choose mine is a 350 sbc
Old Sep 28, 2021 | 10:11 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Stock early C3 SBC front springs were a 250# rate, BBC 284#, and F41 550#.
Old Sep 29, 2021 | 01:52 AM
wwiiavfan's Avatar
wwiiavfan
So do coil overs like this mount to the underside of the lower control arm like the original shocks? If so, all of the load is on those two fasteners.
Or do they shorten the entire shock assembly accordingly so they can mount to the top side of the lower control arm?
Old Sep 29, 2021 | 02:26 AM
trans am kev
no they mount on top
Old Sep 29, 2021 | 04:05 AM
CraigH's Avatar
CraigH
If you go tubular lower arms the lower mount can be bolt through and lower than stock.
Old Sep 29, 2021 | 07:40 AM
wwiiavfan's Avatar
wwiiavfan
Ok, that makes way more sense. No way those two little bolts were going to handle the up and down pounding weight of the car.
Old Sep 30, 2021 | 10:15 AM
RU7376vettes
the coil overs do not put load on the two bolts! They rest on top of the control arm. Ridetec arms lower the shock mount and use a cross bolt. Global West arms use a thick lower plate to support the weight and use two bolts to hold shock to the top of the plate. FYI- Viking spec for minimum lower plate thickness is thicker than thickness of stock Corvette stamped power control arm.
Old Sep 30, 2021 | 10:32 AM
Crimson Thunder's Avatar
Crimson Thunder
I have the single adjustable QA1 coil overs with 450# springs. My car is a 100% street car its fine with the 450"s. I also installed the QA1 11/4 sway bar.
Old Sep 30, 2021 | 11:48 AM
trans am kev
i have just ordered QA1 single adjustable from summit with 550 springs do they come with the top rubber pads for spring pocket . i also have tubular arms with thick solid welded bases
To Viking coil over kit
Old Sep 30, 2021 | 05:52 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Ride quality is about 75% shock valving, but it must be correctly tuned to the spring rate.
With the adjustable shocks you should be able to tune them in to a wide variety of spring rates, and the cars would not ride all that much different.
Old Oct 1, 2021 | 11:27 AM
Crimson Thunder
They do not come with a rubber pad for the spring pocket. They are much easier to install than the factory springs. I hope you bought the optional bearing kit.
Old Oct 1, 2021 | 02:22 PM
trans am kev
did not know about it do you have a link please . is it these . https://www.summitracing.com/parts/qa1-7888-109
