Fuse Box Block
Old May 25, 2021 | 05:36 AM
ApexVette's Avatar
ApexVette
3rd Gear
Default Fuse Box Block
I’m needing help finding the part number for this fuse box block
Old May 25, 2021 | 10:50 AM
torquetube's Avatar
torquetube
If you're just looking for a replacement terminal, the p/n is 12084201.
The connector is a 68-way female "Metri-Pack 280 Series."
The plastic housing is p/n 15319895. A search on that should lead to data sheets with more information about terminal removal, installation, etc.
Old May 25, 2021 | 11:11 AM
Dano523's Avatar
Dano523
As stated, you don't replace the entire block, but just press the pin out and replace the connector with a Metri-Pack 280 Series.
If you check with mouser, should be able to pick up a pack of them on the cheap.
As for the connector, does not look that evil, and standard pick tool to re-bend the connecting piece outwards to make a better contact with the pin, will solve the connector pin.
But the lower pin is not your really problem, and its up in the upper block that is causing all the heat isntead.
What is going on, is the U connector that the relay fuse spade clips into, it either bend open, burnt, or the wire trace that connects to the side of it burnt/corroded, and the real problem that is causing all the heat at the upper blocks male spade connector that is transferring down to the lower block connector.
So short of replacing the entire upper fuse block that the relays and fuses plug into that can get spendy, you can pull the upper fuse block apart to clean up the U tab/bend it back/fix the wire trace connector to it, so it does make clean contact with the relay connector spade pin, and all will be right with the world once again.
https://www.corvetteforum.com/forums...connector.html
And note, that you want to remove the grommet ferrule ring lips on the bottom of the upper fuse block to pull it apart, since the through bolts themselves, will hold the upper fuse block together when it bolted back in place via its center bolts to the lower blocks.
Old May 25, 2021 | 03:11 PM
ApexVette's Avatar
ApexVette
3rd Gear
Thank you I just ordered a few of those connectors
Old May 25, 2021 | 03:12 PM
ApexVette's Avatar
ApexVette
3rd Gear
ok thank you, I ordered those connectors. I will let you all know the results.
Old May 25, 2021 | 11:12 PM
Dano523's Avatar
Dano523
On the upper fuse block once you have it apart, don't need to replace the U pins in it, just clean them up on there contact points to the relay spades, and bend the U back together as needed.
As for the pin connectors (lower and upper box), may be the fuel pump relay pins, and if so and have a BAP in play, need to confirm that the oem fuel pump relay is only being used to control the BAPs own relay that is controlling the BAP on and off.. Also, the OEM power line out of the lower box to the fuel pump harness in back, is not used to send the BAP power to the harness, since the OEM wire is too thin in gauge size as well.
So down and dirty, power out of the oem relay is used for the blue/Yellow (green) wire, and power out of the BAP is run all the way back to the fuel pump connector on larger gauge wiring rated for that increased load.
In not a BAP in play/ not the relay pin for the fuel pump, then figure out what is on that pin adding in after-market that is causing the increased heat and burning problems back up at the upper block U connector.
Old Jul 8, 2024 | 04:32 PM
C6Coach's Avatar
C6Coach
Cruising
can I ask where you ordered the connectors from?
Old Jul 8, 2024 | 05:55 PM
C6ToGo's Avatar
C6ToGo
Mouser.com
Old Jul 8, 2024 | 11:10 PM
C6Coach's Avatar
C6Coach
Cruising
Default C6 Fuse Box Issue
Thanks Man!
Old Apr 11, 2025 | 01:06 AM
melgies's Avatar
melgies
Default Seperate the fuse box
how do I get the fuse box seperated? I cant get the 4 bolts out
Old Apr 11, 2025 | 04:44 AM
Dano523's Avatar
Dano523
If you mean upper block from lower blocks, once you have the 8 center bolts UN-threaded (the metal grommets will retain the bolts in the upper block), you have the un snap O tabs on the sides of the upper block that hook onto the lower block housings tabs,
If you man to get the upper block apart to pull its covers, then read post 4 in the below link that you have to remove the lower flanges on the grommets to begin with, to remove the grommets and bolts,then upper block has hooks that hold it together as well. And reason for lower grommet flanges, is when you put the upper block back on, the bolts will hold the upper block together in the end.
Old Aug 1, 2025 | 10:17 PM
Jkemp007's Avatar
Jkemp007
Default Fuse box block
Hi sir, I am in need of the yellow block, can’t find a part number, would you happen to know it, or point me in the right direction? Thanks
much.
Old Sep 15, 2025 | 10:01 AM
vetteJPJ's Avatar
vetteJPJ
much.
I just repaired my fuse block. Lost one of the bolts. Any ideas. I guess I could get a long bolt from Lowes and use spacer to hold it down. I doubt the bolts are available for sale separately. An ideas? I installed with three bolts and have intermittent starting issues. Thanks.
Old Sep 17, 2025 | 11:10 PM
Qshiplover's Avatar
Qshiplover
I did this "brain surgery" on my fuse box. My post here:
https://www.corvetteforum.com/forums...-fuse-box.html
Old Mar 19, 2026 | 09:38 PM
GA2013C6's Avatar
GA2013C6
4th Gear
Here is the connector housing, site says +6000 in stock, $2.00.
15319895
Conn Housing F 68 POS Crimp ST Cable Mount Gray
https://www.arrow.com/en/search-result.html
Old Mar 20, 2026 | 08:28 AM
WhteldyZ's Avatar
WhteldyZ
And here as well. Took some legwork, but for $9 plus shipping well worth it.
https://www.mouser.com/ProductDetail/829-15319895
The depinning it pretty easy if you take your time. One important tip though. There are these teal, fingered connetor retainers that need to slide out the side of the block. My new block did not come with one. If yours is fried like mine was, the finger that holds the fuel pump connector in is also burnt/broken, meaning once you replace the block, it won't guarantee a solid connection and this could happen again. When looking at the fuse box, the other block closest to the front has these same teal, finger retainers - and no connection in the same location as the fuel pump location on the block you're replacing. I swapped that good one to the fuel pump block and the other burnt one in place of the good one towards the front. That way all connectors are secure and I didn't have to hunt down the connection retainer.
Old Mar 20, 2026 | 09:53 AM
GA2013C6's Avatar
GA2013C6
4th Gear
Good call swapping the retainers, 👍
To Fuse Box Block
Old Yesterday | 01:19 AM
Murli009's Avatar
Murli009
1st Gear
Does this plastic housing from mouser electronic have the female crimps? that's where the Relay sits.
22-20 Ga. Sealed Female Metri-Pack 280 Series Terminals #12084201
Old Yesterday | 05:22 AM
WhteldyZ's Avatar
WhteldyZ
No, this fuse block comes with no other hardware. You must source them separately. Mouser carries them, but I’m terrible at using that site and knowing what I’m looking for. I got the terminals on Amazon.
Old Yesterday | 10:04 AM
C6Coach's Avatar
C6Coach
Cruising
OK thanks, just ordered the female clips from Mouser this will be my second time having this whole thing apart in a couple of years I'm going to do my best to get that clip out of that lower block. May have to use a pencil soldering iron to get it hot enough since it's melted into the plastic. I'll do all the recommended fixes up line all the way to a new relay and see if this solve the issue, at least for a while.
