[C2] Interior courtesy lights?
Old Jul 19, 2021 | 04:23 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Default Interior courtesy lights?
Hello and sorry for the C-2 newbie question.
Does a 1965 convertible have inside courtesy lights?
I see no door switch for activating such.
My head lamp switch has a counter clockwise position to turn on interior lights.
I just took possession Saturday so still learning.
I came out of a 1968 so this is new ground for me.
Thank you in advance.
Marshal
Old Jul 19, 2021 | 04:37 PM
Vet65te's Avatar
Vet65te
Hi Marshall - Just took a few pics of my 66 Roadster and your 65 will have the same inside courtesy lights and activators.
Open the doors and look inside the pocket of the upper door hinge and there will be the spring loaded switch that activates all three lights, one #90 above each kick panel and a single #90 on the rear bulkhead.
If they aren't there, there should at least be the holes for them.
Mike T - Prescott AZ
Old Jul 19, 2021 | 05:01 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
there is also one in the rear storage area under the rear deck
Old Jul 19, 2021 | 09:29 PM
hcallaway's Avatar
hcallaway
Attachment 48336935
Old Jul 19, 2021 | 11:15 PM
marshal135's Avatar
marshal135
Thanks I located the driver's side and it appears the plunger is completely compressed.
Looks like further digging required.
Pictures were a big help.
Thanks,
Marshal
Old Jul 22, 2021 | 06:10 PM
marshal135's Avatar
marshal135
Default Courtesy light follow up
Hello forum,
I have located the 3 interior courtesy bulb sockets. All bulbs are removed by PO.
I ordered a new pair of jamb switches and 3 # 90 bulbs from long island corvettes.
My question is the rear storage area bulb on the underside is awful close to the underside carpet. I’m a little concerned as these little bulbs get awfully hot in a short time.
Did the rear unit ever have a heat shield?
Seems like it would have been a good idea.
The car was built March 1, 1965.
The rear assembly looks identical to the two in the front except it’s mounted horizontally instead of vertically like the two front ones by the kick panels.
Thanks,
Marshal
Old Jul 22, 2021 | 06:15 PM
Nowhere Man
No heat shields. Just how long are you keeping the doors open
Old Jul 22, 2021 | 06:45 PM
marshal135's Avatar
marshal135
Keith, I was thinking along the lines of the bulb shield on the ash tray light on a C3.
I put a bulb in the drivers side socket and it got red hot. I had to use a rag to untwist it.
The bulb is remaining on. I believe replacing the stuck switch will close the circuit.
Marshal
Old Jul 22, 2021 | 06:56 PM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
Marshal,
This is for another day, But! A shutoff switch may be in your future.....for a multitude of reasons......Pretty much why I put one in.......Hate to say it but I've been known to leave a door open!!!And the bulbs can get hot!!
Old Jun 14, 2026 | 12:17 PM
'67 Topless's Avatar
'67 Topless
I am currently working on replacing my courtesy light switches because recently the interior lights will remain on when the doors are closed. The question I have is what portion of the wire
New Courtesy Light Switch
do you remove without damaging it? I purchased new courtesy light switches, which also look different from what were in the car. I am personally not seeing how the connection is made with the wire in the car and the new switches.
Thanks so much for your help.
Old Jun 14, 2026 | 01:02 PM
leif.anderson93's Avatar
leif.anderson93
Did you attempt to "reset" the old switches before buying the replacements?
Old Jun 14, 2026 | 01:09 PM
DZVette's Avatar
DZVette
Topless,
Here ya go:
Old Today | 08:10 AM
'67 Topless
Hi Leif, thank you for the response. I am not familiar with the "reset" process. Is there information somewhere in the forum about this process? Thanks
Old Today | 09:28 AM
65GGvert's Avatar
65GGvert
Open the door, take hold of the tip of the plunger on the switch and pull it out towards you as far as you can then close the door and it will automatically go to the right position if it's depressed past that position the courtesy lights won't come on, pulling it out as far as it will go and then pushing it back in with the door will reset it
do the same thing to the door plunger on the passenger side
Old Today | 09:33 AM
leif.anderson93
Jack was up before me this morning...his instructions are spot on
To Interior courtesy lights?
