C3 Parts for Sale/Wanted C3 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
FS: Diff Rebuild Tool Loaner Program
Old Jul 25, 2021 | 05:18 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Default Diff Rebuild Tool Loaner Program
IN USE -
Sent to: AKJeff (5/2022)
Sent to Tfringo (1/2024)
I loved the way the crossmember tool loaner program went and it helped a lot of people.
I thought this could be sort of similar.
If anyone else is brave enough to tackle rebuilding their own diff, you will need a couple of specialty tools.
Why buy them and have them collect dust for years after?
I will document what is needed here, and offer up my tools for the program.
I do not plan to ever build a diff again.
I also made a few bearing & press tools that are useful, and will include those as well.
Because this process could take a while, I suggest you buy the tools first. I will offer my tools up at half price, or $160.
(The must-have dial inch-lb TQ wrench was $180 alone.)
Then just pass them along and sell them back to the group when you are done, for the same price. So no cost to you!
I only ask that you try to keep all of the tools together to help out the next person.
First Pic:
(Top row) 0-30 in-lb Dial TQ wrench $180 value, (2nd row) pinion holder TQ bracket, Rockwell Hardness Tester File set $70 value. posi rotating tool - homemade, posi holder - old worn out yoke, 28" breaker bar (I removed the not very useful beam TQ wrench)
Second Pic - also included:
(Top)3 inch stack of C3 Posi Shims from 1-1/2 kits, Carrier Shims, Pinion Shims $60 value (Mid) GM pattern paste, 8 ARP Ring Gear Bolts, 3 Diff Seals (Bottom) Pinion Lower Bearing Press Tool, Slip-Fit used Pinion "Set-up" Bearings, Slip-Fit carrier bearing shells for bearing pressing, Ring Gear install screw-in studs
So the first taker gets the use of the disposable shims & seals!
Some other items you will need to do this at home:
Dial indicator & stand
Torque wrenches
Impact gun
Brass drifts 1/4, 3/8"
Brass, Deadblow hammer
Vise
12 Ton Harbor Freight Shop Press or better
Engine Stand
3rd Pic - Hand Tools Not Included
Other required hand tools, not for sale
So whether you want to just replace some leaky seals, change your ring gear, or polish & tune your posi to beef it up, it is do-able at home.
Adding ARP bolts and cap screws is the least you can do, apparently some of those come loose!
I am a rookie at this, but GTR1999 coached me and said my results were at least respectable.
I will be offering some of my left over diff parts for sale in another thread.
Useful Diff rebuild links:https://www.corvetteforum.com/forums...e-it-done.html
https://www.corvetteforum.com/forums...e-w-paper.html
https://www.digitalcorvettes.com/thr...n-units.77377/
https://www.corvetteforum.com/forums...iff-build.html
Old Jan 3, 2022 | 02:34 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
ttt
Old Jan 3, 2022 | 06:36 PM
3154tm's Avatar
3154tm
this is a terrific idea, i hope to do a rebuild as soon as i can find a rebuildable case w/ a posi and hope these tools are still available then. thanks leigh1322!
Old Dec 24, 2023 | 09:36 PM
AKjeff's Avatar
AKjeff
If anybody needs the tools shoot me a PM, I can box them up and get a shipping quote.
I'll have to dig through the spare parts to see what I have to forward with the tools, probably most of what Leigh sent me is still in the box.
Old Jan 26, 2024 | 01:21 PM
AKjeff's Avatar
AKjeff
Tools and spare parts are enroute to member tfringo for his gear swap.
Old Feb 13, 2024 | 10:53 PM
Rv8driver's Avatar
Rv8driver
I would like to be added to the list to use the tools, is anyone in line after tfringo?
Steve
’71
Old Today | 08:45 AM
LT-1 1970's Avatar
LT-1 1970
Is this program still available? I'd like to get in line if so. Great idea.
Old Today | 10:56 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I would recommend private messaging the last 2 guys in the list
tfringo
or rv8driver
Old Today | 11:47 AM
Rv8driver's Avatar
Rv8driver
I never heard from anyone regarding the tools. I ended up buying a rebuilt diff.
Old Today | 01:26 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Send a private message to tfringo
To Diff Rebuild Tool Loaner Program
