This first post will be a running list of parts no longer available. Everyone's help is appreciated.
If you know of a part no longer available from GM please post it here or PM me and I will update the list. If you know an aftermarket source for an obsolete part, please let me know and I will include that info. I will also include sources for repairs and rebuilt parts but not used parts unless it's a source that reliably has used parts in stock at all times.
Please keep your posts short and pertinent or better yet, PM me the info and I will update the list. Let's keep this simple and readable so folks can use it as a reference.
PLEASE: Be concise, accurate and complete. Include part number. Specify if the part only fits some model years or body style(s). PLEASE: REFRAIN FROM POSTING ON ANYTHING OTHER THAN PARTS AVAILABILITY.
LIST OF C5 PARTS NO LONGER AVAILABLE
1. Seatbelts, Torch Red, US spec. Euro spec still available. Check safetyrestore.com for repair/re-webbing
2. EBCM, early version 1997-2000
3. Windshield seal (top and sides). PM me if you know whether this is the same part for coupe and convertible. Bottom seal still available.
4. Fuel hose, rear, w/check valve 1999-2003 p.n. 10448899, 10413425
5. Windshield washer nozzle 6. Headlight adjuster bushing (the part that connects the adjuster rod to the light frame)
7. EBCM. If you've had one rebuilt successfully, please let me know the supplier's name.
8. Steering Sensor, #26058286 9. Steering Column Cover #26061699
10. 1999 brake proportioning valve
11. 1999 - 2003 C5 Corvette Rear Fuel Line Feed Hose w/ Check Valve OEM 10448899
12. Windshield washer nozzle
13. Steering column trim/bezel, GM #26061699
14. 1999 brake proportioning valve
15. 2001-2004 C5 TPMS/KEYLESS ENTRY RECEIVER #10312535, superseded 10431034; 19259165; 10308087; 19259164
16. 2001-2004 Brake line, master cylinder to ABS, #10444144
17. Fog lamps #10438855 and #10438856
18. Grommet, intake air cleaner #25098174
19. 4 Way Flasher #10406626
20. Brake Light Switch #10447139
21. Weatherstrip for the rear window for the Z06/FRC #88948473
In 2008 my ebcm on my 02 zo6 failed. I sent it in to Brandon at ABSFIXER.COM. It came back fixed and stayed fixed until this summer. I contacted Brandon and he said send it in as the repair includes a lifetime warranty. He fixed it again, for free, 14 years after the initial repair.
US spec Torch Red C5 seatbelts. I searched the country over and the very last set was at a dealership in Ohio, but had already been sold.
There are Euro ones available, but I couldn’t ever find out what the difference in them is.
The one that drives a lot of people away from the early models. 1997-early 2000's I believe. The EBCM and it can't be fixed. Need to find a used one and they aren't cheap.
1999 brake combination valve (proportioning valve) with pressure switch - no longer available. Found a used one at Dino’s Corvette Salvage: corvettesalvage.com
I just found a place for the seat belts, thanks to another forum member. I just bought a 2001 Coupe Torch Red w/Torch Red seat belts and I need to get the driver retractor fixed. In any case...Safety Restore - Westfield, MA claims they can "color match" most any belt. It was to late yesterday when I got the information but I plan on calling today.
My Manuel HVAV control works as it should but the face plate showed cracks when the lights were on, I found that the 00,01 Pontiac Montana HVAC control face plate is exact fit other then the color of the ***** and buttons. was a easy switch over and now my control looks new. Was only $30.00 on e-bay , replacing it with a 20 year old part from a C5 was going for $400.00 +
[QUOTE=Lil Blue Coupe;1604225143]does anyone know where a guy can get a drivers side mirror for an 04 coupe?
the housing is good but the mirror itself... well, uumm not so much
Go online. You can find a mirror with adhesive to stick over top, I believe
The 2001-2004 C5 TPMS/KEYLESS ENTRY RECEIVER has been discontinued. I am having a very difficult time finding one. The receiver for the Z06 does not support TPMS, so it is different from the Coupe. The part number for the Coupe Receiver is GM 10312535.
Apparently, the Keyless Entry/TPMS reciever for a Z is a different part than for other models. It is a different part number, and I am told it does not support TPMS.
I have no idea if the part number for receiver is different in a Z06 but I can tell mine was simply turned on by my person that tuned my car. So the “part” must have already been there.
