64-5 Chevelle Wheel/Tire Size Question:
Old Nov 15, 2021 | 09:20 PM
Chambered's Avatar
Chambered
Default 64-5 Chevelle Wheel/Tire Size Question:
I know - I know - this is a CORVETTE forum, but I figger y'all have had a bunch of different stuff over the many years.
I've got a customer asking me if he can go to 15" steelies on his 65 Chevelle, & what kind of width will fit? (I used to deal in steel wheels back when I had a source for them). The rear wheel openings on these year Chevelles were a bit tight, so I'm not sure what to advise him. I still have a set of 15x7" GM's but not sure if they are going to cause interference for him anywhere? Any advice or knowledge appreciated!
Old Nov 16, 2021 | 08:22 AM
Corn Fed's Avatar
Corn Fed
On my 65 Chevelle convert I have 15x7 GM 5 hole Rally's on the back with 235/75's. I have to jack the car way up, put jack stands under the rear frame rails, and then lower the rear end all the way down just to get them in. The trick is to kind of roll them in from the rear instead of coming in from the direct side like you tend to do.
Old Nov 16, 2021 | 09:37 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
I have 15x6 with 215/75/15 tires on my 66 SS with bone stock suspension and it barely clears
Old Nov 16, 2021 | 10:57 AM
AlHewitt's Avatar
AlHewitt
I have 15" X 8" Cragar SS wheels with P225/60R15 tires. The fronts are fine but the rears are very tight. As per Corn Fed above I have to remove the bottom shock to get the tires installed. I also have stiffer springs and car's ride height is higher than stock. If your car is lowered it will be more problematic... Al
Old Nov 16, 2021 | 11:28 AM
Chambered's Avatar
Chambered
Excellent info - thank you! I passed this stuff on to my customer.
Old Nov 16, 2021 | 08:26 PM
CorvetteMikeB's Avatar
CorvetteMikeB
I like your white letter tires. Are they brand new? Does the white lettering turn brown overnight and impossible to stay white?
Old Nov 17, 2021 | 08:21 PM
AlHewitt's Avatar
AlHewitt
My tires are 5 years old, easy to keep the letters white and clean. I got stupid once and kissed a curb. Fortunately I did not hit the rim but the white letters took a beating. They clean up nicely with SOS pads or use MEK to remove tare and road dirt... Al
Old Nov 18, 2021 | 09:46 PM
GUSTO14's Avatar
GUSTO14
My tires are 5 years old, easy to keep the letters white and clean. I got stupid once and kissed a curb. Fortunately I did not hit the rim but the white letters took a beating. They clean up nicely with SOS pads or use MEK to remove tar and road dirt... Al
...but with caution and in a well ventilated space...
Good luck... GUSTO
Old Nov 20, 2021 | 03:19 PM
GTOguy's Avatar
GTOguy
Nice '65, Al! Love the color combo and choice of rolling stock. Very, very clean.
Old Yesterday | 12:46 AM
romur199's Avatar
romur199
1st Gear
hey Al what sort of springs did you use for your suspension upgrade , It looks great and sits well
Old Yesterday | 08:33 AM
Tampa Jerry's Avatar
Tampa Jerry
Tell your friend to log on to Team Chevelle. It is a forum like ours, except for Chevelles. Jerry
Old Yesterday | 09:42 AM
Nowhere Man
after five years I'm sure they figured it out
To 64-5 Chevelle Wheel/Tire Size Question:
