I couldnt find a cell phone holder that suited my needs so i designed my own which i now have in stock.Its called "Cell Mate" and It simply attaches to the center console lid with a bottom bracket as part of the mold. This bracket is also lined to prevent any scratching. There is also a cable charger hole in the bottom middle and now you only need a 4 to 6 inch cable for charging. If you all ready have a holder you might consider this as a second option due to its ease of use. Great for quick trips, Put it on and take it off in seconds to store in the center console when not needed. Its designed to fit most cell phones and measures 3 5/8 inch wide with a 5/8 inch thick holding capacity. There is an opening on the middle back for those who have one of those Pop Sockets which once inserted open and then push in, holds the phone in very secure. Those with out it can use the charger cable or use the 3 inch piece of stick foam i have included to tighten up the sides for any phone movement. Ebay item #234891605030
Adrenaline red
Reason: change in sale date
I couldnt find a cellphoneholder that suited my needs so i designed my own which i now have in stock.Its called "Cell Mate" and It simply attaches to the center console lid with a bottom bracket as part of the mold. This bracket is also lined to prevent any scratching. There is also a cable charger hole in the bottom middle and now you only need a 4 to 6 inch cable for charging. If you all ready have a holder you might consider this as a second option due to its ease of use. Great for quick trips, Put it on and take it off in seconds to store in the center console when not needed. Its designed to fit most cell phones and measures 3 5/8 inch wide with a 5/8 inch thick holding capacity. There is an opening on the middle back for those who have one of those Pop Sockets which once inserted open and then push in, holds the phone in very secure. Those with out it can use the charger cable or use the 3 inch piece of stick foam i have included to tighten up the sides for any phone movement. Ebay item #234891605030
