C4 Corvette Rough Idle Normal?
Old Apr 16, 2023 | 10:50 PM
ChaseC4Vette's Avatar
ChaseC4Vette
Default C4 Corvette Rough Idle Normal?
Hey guys so i got a quick question i have a 1996 C4 Corvette LT1
Its got a bunch of new things everything within ignition and sparks and such have been replaced i was chasing a rough-ish idle for about 5 months and $8000 later including a new trans and torq converter she still has a kinda shaken idle nothing crazy!
I was really thinking then i thought omg what if it was just motor mounts but my main question is i know it’s a basically 30 year old engine do most have a shake at idle?
Old Apr 17, 2023 | 02:55 AM
Vwaggs's Avatar
Vwaggs
Cruising
No, unless it has a hotter cam, it shouldn't. Now as to finding the reason, that's a bit harder. I just got done chasing my idle, performance issue down in an L98 and after new fuel filter, de-carboning the engine, cap, rotor timing adjust, knock sensor. I discovered mine was the timing module.ultimately. It can get crazy, I read one guy who posted somewhere his cigarette lighter didn't work and after fixing the ground, discovered it also fixed the signal through the brake switch to activate the torque converter locking.
Old Apr 17, 2023 | 02:07 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
A bunch of things can cause a rough idle…I see your in Florida so if you’re near me in the Southwest bring the car by and I’ll take a look at it for you…a scan tool is needed to diagnose this…if not using one you’ll just be guessing.
Old Apr 17, 2023 | 02:55 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Can you put up a video of the engine at idle? We all have different ideas on what constitutes a shake. Our engines all have a little movement but some of us are more attuned to the movement. You could have a problem or be just fine. Put up a video and we can take a look.
Old Apr 17, 2023 | 05:02 PM
ChaseC4Vette
Hey man yeah i’m in Naples Florida actually if you wanna shoot me a message i would love for someone to maybe look at it like i said the car was in the shop for 5 months
New Ecm
new ICM
new fuel pump
new fuel filter
new fuel injectors
and a bunch more
but if you can shoot me a dm id love to have you look at it
Old Apr 17, 2023 | 05:24 PM
C5 Diag's Avatar
C5 Diag
New Ecm
new ICM
new fuel pump
new fuel filter
new fuel injectors
and a bunch more
Will send a PM !!…5 months in a shop and all those parts ??…if it was a general repair shop or a dealership they just replace parts until they get lucky…99.99% of them don’t know how to diagnose unfortunately….would like to know what the other “bunch” was…LOL !!
Old Apr 17, 2023 | 05:35 PM
ChaseC4Vette
This doesn’t include the rebuilt trans and new upgraded torq converter
Old Apr 17, 2023 | 05:43 PM
ChaseC4Vette
It won’t let me upload video to many MB even for a 9 second video lol
Old Apr 17, 2023 | 07:08 PM
C5 Diag's Avatar
C5 Diag
HOLY CRAP !!…well this is what happens when shops don’t know how to diagnose...they just guess !!…I don’t care what was changed so I don’t base my diagnosis on that…I’d be looking for a EGR valve that may be stuck open or partially open giving you a rough idle and the car runs better above idle…saw in a previous post you had some starting issues…classic stuck open EGR…I’d be looking for elevated fuel trims and lower engine vacuum…also the solenoid is duty cycle controlled so I’ll be looking at that too.
Old Apr 18, 2023 | 01:18 PM
Talfryyn's Avatar
Talfryyn
I guess they make more money on parts than checking cylinder compression balance.
Another sneaky EGR like symptom is a leaky A.I.R check valve.
Old Apr 18, 2023 | 02:13 PM
C5 Diag's Avatar
C5 Diag
OP is bringing his car by this weekend….I do a relative compression on EVERY car I look at and everything will be checked and a 100% diagnosis’ guaranteed…LOL !!
Old Apr 18, 2023 | 06:51 PM
Vwaggs's Avatar
Vwaggs
Cruising
I didn't on mine because it only had 50k on it. That is the best place to start though. Don't forget to thermo check the cats for being clogged.
Old Apr 18, 2023 | 07:09 PM
C5 Diag's Avatar
C5 Diag
Doing a relative compression on every car is always part of my “diagnostic process”…I also do a starting and charging system check too…don’t even have to open the hood for the relative compression…do it right from the drivers seat…thermo gun for me isn’t the best way to check for a clogged cat…I’ll either remove a spark plug on each bank and do an incylinder pressure analysis (below pic) on each side or remove the upstream O2 sensors and hook up a pressure gauge.
Old Apr 18, 2023 | 07:45 PM
Vwaggs's Avatar
Vwaggs
Cruising
Some of still live in the stone age and don't have fancy equipment, LOL. Not to hijack the thread, but since you seem to have the knowledge .... My 1987 L98 has no power reading to either side of the dual brake/cruise switch on the cruise part. I was thinking I could run a 12v hot to it and see if my cruise works. I don't know where I can get a wiring diagram to pull the cruise column wires and add an new ssh mount switch. .Even in PM, thoughts would be appreciated. Thread ... https://www.corvetteforum.com/forums...ke-switch.html
Old Apr 18, 2023 | 08:29 PM
C5 Diag's Avatar
C5 Diag
Sorry but I don't have the wiring for the CC for an 87...if no one can supply one you can go to Alldata and get a 1 month subscription for $19.99...well worth it and the wiring diagrams are excellent !!
Old Apr 26, 2023 | 06:26 AM
sdshaw1965's Avatar
sdshaw1965
Please keep us posted. Following closely, thanks.
Old Apr 26, 2023 | 10:57 AM
C5 Diag's Avatar
C5 Diag
Didn’t hear from the OP this weekend so don’t hold your breath…LOL !!…are you experiencing something similar ???
To C4 Corvette Rough Idle Normal?
Old Apr 26, 2023 | 12:54 PM
sdshaw1965's Avatar
sdshaw1965
Absolutely. Been chasing a low rpm (~1200) shake for a while. Opti is new, needed as it was throwing codes. Wires plugs last year. Lets just say all sensors as well.
Shake started a few months ago, but not seemingly related or in correlation with any work performed.
Higher rpm feels good. 94 6spd. Mileage could be better, around 17-18 city. Daily driver.
I did the injector test, disconnecting one at a time, and #2 shows no significant change in idle when disconnected. That was going to be my next potential source, but haven’t gotten around to that yet.
Been running Mystery Oil through it, and that improved mileage substantially. At that time, it was at 15-16 city.
Old Apr 26, 2023 | 01:08 PM
InfomanSS's Avatar
InfomanSS
Setup a YouTube account and upload to there, then post the link here. When you upload the video to YouTube you can also set the privacy to not be public. This will let people that you give the link to view the video, but it won't be available to the rest of the world even it they go directly to your channel.
Old Apr 26, 2023 | 01:09 PM
C5 Diag's Avatar
C5 Diag
I don't do a lot of OBD1 Corvettes down here in the Sunshine State but from what you're saying it sounds like a vacuum leak..you said it runs better at higher RPM's and that is what you'll see with a vacuum leak...you have less manifold vacuum at higher RPM and a leak has less of an affect...shaky at idle but runs better higher RPM...you can either spray some Brake Kleen around any vacuum lines/intake runners and see if the RPM changes....just be careful with that stuff since it's pretty flammable....propane is what I use now...good luck !!
