Driver head coolant temp sensor wires
Can someone tell me which color wire goes where on the coolant sensor pigtail? i took a reference photo for EVERYTHING I depinned except for this one apparently.
Ok, my coolant sensor plug broke, the replacement plug that I have to splice on doesn’t have tan and yellow, it has one black wire and one white wire. So do I connect the white wire to the tan low resistance wire and the black to the yellow temp sensor signal wire or vice versa?
Received 1,801 Likes
Post #4 in this thread talks to the colors and position on the connector. You should be able to figure it out from there I think https://www.corvetteforum.com/forums...n-2005-c6.html
