Had My E-Ray Alignment Checked
E-Ray, 3LZ, ZER, LIFT
Received 9,683 Likes
Have about 1000 miles and driven over enough RR Tracks to have the suspension bushings worn it! GM is fussy having alignments done on warranty. Requires relative low miles and "customer" mentioning some steering issues. In addition to E-Ray pulling slightly to the right on our narrow rural roads (because of rain drain road camber, all cars will pull slightly) mine is a bit jumpy on some roads. The Chevy Service Writer carefully wrote down my statements for his warranty reimbursement paperwork.
Reminded of some of what I felt was similar my 2017 Grand Sport with its wide tires grabbing when driving in the right lane on the 4-lane divided highway at the end of our rural road. With heavy trucks driving in the right lane (many log trucks going to the papermill) they create mostly invisible ruts. The 275 front and 345-section width tires grab the rut edges! Also trying out Lane Maintainer and in the right lane between the two, steering is a bit jerky.
The Chevy/BMW/Mercedes dealer in town, who also did my 2017 Gand Sport alignment, have a new Hunter drive on rack and measuring equipment.
The only alignment specs in the Owner's Manual are for Tracking (~2.5 camber) so tech used the Hunter Specs. Thankfully it showed:
"E-Ray with RPO FE5 Suspension (with All-Season tires) and FED ZER Suspension (with Summer tires, which I have.)"
Specs:
Front Camber (Left and Right) of -1.0 deg. The allowed range +/- 0.6 degrees.
Toe Total of + 0.10 (-0.05 min; +0,15)
Caster = +8.0 (acceptable range +8.6 to +7.4)
Rear Camber (Left and Right) of -1.0 deg. The allowed range +/- 0.6 degrees
Caster: Hunter did not measure rear caster. Nor would I left anyone other than one experienced with racing and having done many Vettes touch those adjustments! A number of posts where handling was terrible when rear Caster was not done properly!
Unlike my C7 Grand Sport where particularly rear camber was near MAX negative and I had brought closer to centerline, all my E-Ray values were close to the centerline spec. No adjustment needed.
Yep, the steering issues I feel are road related. Also, a small amount of torque steer for an instant when accelerating.
Specs:
cwaddell (04-11-2024)
Good info, thanks for sharing!
JerryU (04-11-2024)
So what's the take home message?
As I did:
Suggest saying "Feels like it's pulling somewhat to the right." It will do that on all narrow two-lane roads where the "road camber" is built to have rain run to the edges. Service writer needs to put some customer comment as an "issue" on the on the warranty submission paperwork. In my case with the wide E-Ray tires it does grab ruts on the right lane of a four-lane highway where heavy log trucks often travel. Can't see them BUT can feel the car jerk as the tires hit the edges. Service Writer wrote that down as well. It will do that on multilane asphalt roads where heavy trucks travel on the right lane. Wider tires make it worse. In my case wanted to be sure it was the road NOT alignment.
If you're not capable of detecting or don't want to say that, just leave it as it is and live with whatever tire wear you get! BTW anytime you get new tires or even between, smart to pay for an alignment. Does not take but a few hard hits in potholes etc to have it go outside of even GM's wide allowed range.
- With my 2017 Grand Sport (and had it changed from near Max allowed in the rear of -1.7 degrees Camber to about mid-range, -1.0 degrees) or
- My 2020 C8 where when checked all were close to centerline EXCEPT one rear toe in Red, which was fixed.
- My E-Ray, checked and found most were centerline so no change needed:
As I did:
JerryU (04-28-2024)
Specs:
Specs:
For my C7 Grand Sport where they changed my rear camber from close to the max allowed for street driving -1.7 degrees to ~ 1 they did not touch the rear caster adjustments that are different. I have the 4 volume C7 service manuals. Would not allow anyone except someone who had the experience setting up Tracking Vettes touch the "different" caster adjustments and know how to use the special measurement tool! A number of reports where it was done incorrectly and created significant issues.
Don't recall reading where the rear caster adjustments are for the C8 or what special measurement tool might be needed. My inexpensive CD C8 service manual is too hard to search. Perhaps one with better source can check.
Enough posts like these below that I would not allow the average Tech to measure or adjust rear caster.
Post 1: The 2 tools needed are Digital Angle Gauge Adapter (CH-47960-10) & Digital Angle Gauge itself (CH-47960). These tools are not normally kept at dealers due to the very high cost & limited use/need. They are ordered by the dealer thru GM Special Tools website thru the Global Connect Link which has a LOAN TOOL button that is accessed once at the Global Connect Link site. The tools are shipped 2 day delivery to dealer & can be kept for I believe 48 hrs at no cost to YOU or dealer, then shipped back. So they should get tool ordered & your appointment co-ordinated to meet these requirements. Just double checked my info on Google. The dealer has to be in the tool loan subscription program (annual fee) & the tool can be kept 5 days.
Post 2: THIS!!! I was told the same thing AFTER they did my alignment and it was so out of whack afterwards that the car felt EXTREMELY unstable over bumps. I ended up taking it to TPC in Maryland to get the alignment done correctly and they said my rear drivers side caster was +1.7 degrees and the passenger side rear caster was -1 degree. Basically, it was WAYY out. If you have the same luck I did, you won't find a dealership that can do the alignment properly. I called 10 dealerships and NONE of them had the tool or even knew what I was talking about (2 of the dealerships were SPECIFICALLY Corvette dealerships). Check out the video here if you want to hear/see more:
Other similar with misadjusted Caster:
Perhaps I read incorrectly but know toe and camber were iterative but thought Caster was not as significantly affected as it is with toe. Tech had to adjust both on my 2017 Grand Sport rear toe and camber several times. They not only did not have the measurement tool (or probably how to use) but would not allow them to adjust if they did, because of the folks who said it was screwed up badly after they had an alignment.! Started at 16-133 with pics of how to install and use measurement tool. Step 6 was install Caster measurement tool.
I would say that if you let them adjust camber, then by default you have let them adjust caster. And if they do not measure and adjust caster, they probably messed it up. There is always the possibility they got lucky and the caster was OK. That could only happen if they moved each cam the exact same amount, and that is not likely since the cams tend to be not very precise.
That was two Vettes ago and my 2017 Grand Sport where the rear camber adjustments were made. Rear camber from the factory was ~1.7 near the max in GM allowed range. Car handled great for the 3 1/2 years I had it.
My 2020 C8 Z51 did not need any change in camber, only a rear toe adjustment. Car sold as well.
As I noted for my E-Ray all was close to center of GM acceptable range so no changes. In neither case did they measure rear caster!
