what is this
what is this
This connector appeared after I removed and replaced the steering column in my 1977. I pulled the column several times to make it easier to get the driver side dash pad out. It's always gone in easily in the past,
this time has been a challenge. Only courtesy lights, when I move the ignition switch the lights dim or go out. The fuel gauge is pegged past full. I put in a new radio and the hot always circuit is good but no power thru ignition. Did I miss something? Does it have anything to do with this connector. It's located on same bundle as headlight switch just below it. The connector is hot all the time two orange and one white wire. The wires it is attached to bend around in a tight curve. Guy before me screwed with the alarm system and tried to add cruise so I have a bit of a wire jungle behind the dash.
Brake switch connector. Do your brake lights work ?
Received 4,643 Likes
Cruise-In VIII Veteran
As always, what doesn't work? Usually points me in the right direction!
whats this
Thanks for the help all, connector is back where it belongs. Now what is this one? Live all the time, one orange one pink, goes to fuse box.
Spoiler
Received 1,306 Likes
I'm telling you, get the 1977 Electrical Troubleshooting Manual and this 77 could have been on the road already...lol
On the buzzer one terminal has a small protruding bump.
They did that so the connector could only go on the buzzer one way...
I guess you could cram the connector on the other way but that would be incorrect...
Shorting out the buzzer unit....
Cannot find where this one goes. I also found the anti-theft warning switch hanging with the threaded end broken off. The anti- theft has never worked, I have no key and the key slot is not original.it is a round key. I have the trouble shooting guide but still can't find where the blue connector goes. All the wires that should have power without the ignition switch turned on seem to have power but the ones that go thru the ignition don't. Turning on the ignition does nothing. The courtesy lights come on when door is opened but dim when the ignition key is turned. Any one have any thoughts? I can' find any other loose connections. The anti theft warning switch being broken I have never seen before and I have had the steering column and dash out more than once and never this type of problem.
