M7 Shifter vibration
Does this seem excessive? In N just idling the shifter vibrates. So much so it vibrates my hand as shown. MGW & have the solar TB.
Clutch fluid is fine. Did the modified Ranger 2 months ago. It's not as bad when the car is cold. Actually I've noticed several things in the car rattle like that when idling. I wonder if this is just the normal chop? Given the MGW parts that secure it, the entire structure is now more ridged & rattle in unison with the car?
H Watkins (05-14-2024)
Moderator
Mine never did that.
Scientific Negotiator
Received 1,856 Likes
St. Jude Donor '07-'08-'10, '14
You will feel it more if you have a delrin or solid bushing mounted aftermarket shifter or box. The stock box has VERY soft bushings to help soak the vibrations up. I've had just about every combo of shifter and box on these cars and depending on the mount you will feel it and see it more. MGW is up there on the list for solid mounting which is a great thing, this is a side effect. The swivel on the MGW and cup system are far more precise too, transferring even more through the shifter.
This is a side effect of these awesome shifter systems. MGW is awesome.
Mine doesn't vibrate at all. 2017
Mine isn't that harsh but mine does vibrate at idle.
NortonCO (05-19-2024)
So I wonder if this is a miss @ idle? I'll need to dig into it when I have time. The car has since I got it seemed to idle a bit choppy. I initially thought it was a miss but everyone said it was normal for a Corvette. I'll check the engine mounts as well for play.
M7 2015 with Soler TB and MGW - No vibrations
I checked RPM & it's steady idle at 600. If I rev it to 7-800 the vibration is gone. I guess it's something with my specific car. Drives fine.
Dont fix what's not broken.
