2011 c6 GS 4LT Fuel Pump Relay issie
Hi guys, I'm looking for a source for either a new (GM discontinued part) or refurbished
Engine Wiring Harness Junction Block (Main Fuse Box)- GM (22739140) as you may know, there's a known issue with the clips in the box that contact the pins for the electric fuel pump relay. They overheat and lose contact overtime. I have re-positioned that clip several times which is just a Band-Aid. It continues to fail so I'm looking for the box itself preferably new or refurbished. Lyle at C&C Corvettes Identifies the issue here:
As for lower fuse block connector, Mouser sells them so easy to replace, and on upper fuse box, easy enough to pull it apart to not only clean the corroded U clip, bend it back to shape, and even temper the U clip so it not bending back open with ease.Hell, push comes to shove, mouser even sells the U clip if you just want to replace it in the upper fuse box.
https://www.corvetteforum.com/forums...box-block.html
Hence entire problem can be solved for few pennies in the first place from not replacing or cleaning the relay when it first appeared to start looking burnt, and just a little labor time now.
The other problem that can happen, changing out the fuel pump to after market with more current demand, while the wire gaging is not large enough to carry the load, causing not only problems up at the fuse box, but problem with wire in the loom to the back doing a melt down as well.
https://www.racetronix.biz/p/c56-fue...rness/fpwh-008
One more question someone else had mentioned that once the new box is installed it has to be flashed to the ECU which doesn’t make sense to me unless there’s a computer in the box itself that I’m not aware of any insights to that?
On upper fuse box, ebays has them for sale all the time used,
and if push comes to shove, heat gun to remove the U connector and reinstall a new one, will solve the slightly melted plastic housing problem.
But does come back to why you cooked the first one, and have you solve that problem so your not going to cook another.
Do you have a link / number for Mouser? I l looked through the other thread and didn't see one.
Next it sounds like just replacing that relay will fix the original problem. Is that correct?
Same goes for the lower block connector as well.
Truth is, the only time you need to go to external relay, is when you replace the fuel pump to something that is drawing more current, and the the oem wires from the fuse box to pump on oem harness, are not large enough to take the extra load without out the doing a melt down in the first place.
When I went in there to attempt to replace that clip it had already melted into the block itself and was not able to pull it out even with the heat gun.
Is there any way to replace the entire block? And if so, what's involved I see it's a direct wire to the harness and or any ideas on how to get that clip out and the sources for that clip?
