Frunk Latch Issue
The hood will not go up and the soft close will not pull it down. So it wont open and it wont close.
The manual release also did not resolve the issue. Took it to the dealer to have it looked at but have not heard back yet. That was a fun drive at no more that 26 mph.
Anyways, just curious if anyone else has had a similar issue. 2024 with 5500 miles
Thanks
Just fully close the frunk with the Tender cord coming up by the driver's side windshield wiper. It will not hurt the gasket. If worried move the cord around to a different spot of the gasket.
https://www.corvetteforum.com/forums...k-problem.html
All the best.
i almost split my fonger trying to pull the wire,, most stupid thing i ever seen,,,,,,,, oh sorry in 2023,, there is another stupidity,,,, no manual opening for the trunk,,,,,
What i did,,,,, i had to sleep there for the night,,,,, i expected the weather would drop a bit (metal expand when warm) and effectively at 05:00 the day after,, i tried again and finally get de second latch to release ,,,,
The delaer replace the whole thing,, latch ans cable,,,,,,,,, surprise: There was a lot of latches in the GM Warehouse,,, that let me conclude that GM knows the issue and wait for the call instead of being proactive.
Another , get a hook ,, otherwise your finger will suffer,,,,,,a lot
Good luck buddu
Thanks
Luckily, I was at home in my garage just testing it out, or I would have been really stressed if my battery was dead.
These things just add weight, complexity and they're just one more thing to go wrong, they should've just used a door latch.
Yes, this just occurred with mine - on the Tender with frunk slightly open ... used the fob as it would not 'latch'.
Thought soft close was into'd in 2025? It was a 2024 feature too?
