76 Corvette Air Conditioning fix original or replace with aftermarket system ??
it's up to you
The original system has many parts that should work just fine. So a complete aftermarket replacement is likely not necessary. Although many do just this and swear it's the best answer, cost be damned!
The VIR system worked very well with the R12 refrigerant of the day. But R12 is difficult to find and expensive when you do. So repairing as per stock standard is possible, but unless your looking for that NCRS perfect original car. Doesn't seem practical to most.
upgrading the car to use a more modern orifice tube set-up. Modern compressor, condenser and dryer can be done without completely gutting the car. As in a complete aftermarket system, evaporator and all.
There is more than one way to skin a cat. One would need to determine the condition of all components before making a informed decision on the best way to attack the problem.
Compressors can be resealed if they are not scattered. All the rest is a judgement call.
- see what gauges say
- does it hold vacuum?
- do you know what refrigerant and or lubricant is in it?
show a bunch of pics on hoses compressor etc.. maybe it has been converted.
Having been where you are. if i had to do it all over..
- flush system
- replace compressor with Sanden compressor.. the old ones are good but they really draw power..
- run available refrigerant and proper oil
- new accumulator
here is a decent article
https://www.motortrend.com/how-to/18...oogle_vignette
too bad you do not have orifice to look at for debris..
All that said i stayed r12 and replace OEM style compressor and accumulator. Still running since.
not exactly same as yours but here is my latest update.
https://www.corvetteforum.com/forums...questions.html
I get that. If I buy this 50 year old car what am I getting into?
Truthfully, the air-con is likely to be the least of your worries on a 50 year old vehicle.
As I believe I already stated, the VIR system worked very well back in the 70's when that refrigerant was readily available. Some people find cans of it on Ebay and the like and purchase these vintage cans of refrigerant and DIY their air-con.
Common problem is the system isn't adjustable to different types of refrigerant. So you can convert it over to modern gas. But it won't be great. In fact, it won't be acceptable.
So, you can convert it. I have a excellent thread on here discussing the process of converting the system over.
Just Google corvette 73-E77 Air-Con upgrade. It should pop right up and take you back to this forum.
A 50 year old system could have any one of a number of problems. So a nice, simple answer to your question just isn't possible.
If you are a very handy guy and love working on old cars.
Dive in. We are all here to help with knowledge and advice.
If you are looking at a vintage Corvette and want to pay a mechanic to repair every little thing. You should be prepared to spend far more than the cost of the car to keep it maintained.
Maybe a different car with a working A/C system would be a better choice.
The A6 wobble plate compressor in these GM cars is really a great compressor. It has a lot of cooling capacity and is very reliable. Too bad it's so damn heavy. Wish they'd made an aluminum version with iron sleeves for the compressor. These compressors were used in Rolls Royces, Bentleys, MBs etc. Since the interior of Corvettes were easier to cool that a full sized GM sedan of the 60's and early 70's, their A6 compressors were reduced in capacity to decrease their HP drag on the engine. These compressors had reduced compression ratios.
Great decision making Post. Gracias
