Autocrossing & Roadracing Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results
Anyone Use the ARE LS7 Dry Sump Pan?
Old Feb 12, 2026 | 07:43 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default Anyone Use the ARE LS7 Dry Sump Pan?
I am building an LS3 utilizing a factory dry sump setup. I have a larger C7 oil tank, C6Z pump, front cover, pan and pickup. I also got a ARE #1007-1 pan for cheap, but then I got some feedback that they are not that great. I dont have the budget for a full blown dry sump, just looking for some improvements on the factory setup. I like the idea of the built in crank scrapper, now that IR doesnt make on anymore, and the smaller sump to help suck oil from the pan. Has anyone used one and it led to low pressure or engine damage? Anyone have success stories?
This is the one Im talking about:
https://www.drysump.com/index.php/oi...p-oil-pan-1007
Old Feb 12, 2026 | 05:06 PM
on track's Avatar
on track
Depending on the track, I'd either do a lagit dry sump or run street tires w/1 qt over. Its the big sweepers while on slicks that can blow your engine. Trying to patch the factory setup and rolling the dice is a recipe for an expensive track day.
Old Feb 12, 2026 | 06:28 PM
Kubs's Avatar
Kubs
I already run 200tw tires. I'm building and engine too and can't do both that and a dry sump.
Old Mar 3, 2026 | 02:09 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Then how about a accusump as a interim? At least till you can afford the system you want
Old Mar 3, 2026 | 02:25 PM
Kubs's Avatar
Kubs
I already have a 3qt accumulator. I am replacing that setup with a factory dry sump, which is larger capacity and more effective. Im just looking for specific experience with this pan vs a stock LS7 pan.
Old Today | 04:00 AM
MURDEREDOUT's Avatar
MURDEREDOUT
I have the whole ARE set up. I think the benefit vs a stock LS7 is you will have a better oil filtration system. I saw you are using C7 dry sump tank already. I thought about doing that also. How are you adapting to those lines?
FYI Katech has a bunch of ARE lines on sale/clearance at the moment.
To Anyone Use the ARE LS7 Dry Sump Pan?
