2003 ZO6 Headlight Issues
Old Feb 23, 2026 | 08:07 PM
CRVETTE92's Avatar
CRVETTE92
Default 2003 ZO6 Headlight Issues
My headlights pop up at random alot, even when they are off. Usually I need to talk on them or open the hood and drop it for them to go down. Any input on the possible issue? By the way I already cleaned the grounds associated with the headlights.
Old Feb 23, 2026 | 08:22 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
gears or bumpers worn out ???
Old Feb 23, 2026 | 08:51 PM
hyperv6's Avatar
hyperv6
Yes check the bumpers. One I likely worn if out of place.
you can move one from the back to the worn one till you get replacements.
Rodneydicman.com is the best replacement.
Old Feb 24, 2026 | 08:48 PM
And moved to C5 Tech.
Old Apr 24, 2026 | 01:21 AM
CRVETTE92's Avatar
CRVETTE92
Bumpers are fine but still having the popping up randomly issues. Also, the head light motors still spin after the actuation is done. Could it be a bad headlight module?
Old Apr 24, 2026 | 09:10 AM
mmartinez's Avatar
mmartinez
Most likely the plastic gears are stripped.
Old Apr 24, 2026 | 09:02 PM
CRVETTE92's Avatar
CRVETTE92
Probably. I got some brass gears I'm putting in this weekend.
Old May 23, 2026 | 09:26 PM
CRVETTE92's Avatar
CRVETTE92
I replaced the gears but still having the popping up issues. Any other suggestions?
Old May 23, 2026 | 10:00 PM
LegionnaireCM's Avatar
LegionnaireCM
Sounds like the motor housing cover could be flexing and unlatching. If the motor casing is tight, not flexing, possibly a headlight control module.
Old May 24, 2026 | 01:33 AM
CRVETTE92's Avatar
CRVETTE92
What would you suggest if indeed the cover is flexing? JB Weld it close?
Old May 24, 2026 | 04:59 PM
LegionnaireCM
If it's flexing or splitting under load, it needs to be heavily clamped and re-glued with structural epoxy, braced with a reinforcement T-bracket kit, or the motor assembly might have to be replaced. My neighbor’s C5 is doing this, currently. It’s not uncommon from what he’s saying.
To 2003 ZO6 Headlight Issues
