Sponsored by: Wheel Design
Apple Car Play
Old Feb 25, 2026 | 08:50 AM
JRYELLOWCORVETTE's Avatar
JRYELLOWCORVETTE
Default Apple Car Play
Very often it is difficult or impossible to get my phone to link up with Car Play on my C8. In my other vehicles it never fails. Am I doing something wrong? Do you have to have the phone in a certain mode to get the car to recognize Car Play?
Old Feb 25, 2026 | 09:53 AM
vacek's Avatar
vacek
I had this frustrating issue last summer. Here is what helped/solved for me:
Ok, I figured this out after 3000 iterations trying just about everything. (iPhone 18.4.1 IOS, but I also upgraded to the latest beta 18.5 Beta 3 , but exact same issue)
First, go to Settings > System > "Return to Factory Settings"
Then "Erase Settings and Personal Data" (caveat, this does EXACTLY what it says )
Remove the car from CarPlay on your phone ("Chevrolet" in my case)
Then I re-setup all my personal settings (add KeyFob back, set seats again, logged into my account with my same email and ran through all the settings to make sure things are where I like them.)
Touch "CarPlay" on the screen, open CarPlay on your iPhone and reconnect Wirelessly ...
Back in action, all working as it should.
Old Feb 25, 2026 | 10:29 AM
Ken_C8's Avatar
Ken_C8
St. Jude Donor '09, '21
Resetting the car probably works but has a lot of side effects.
I suggest deleting the phone from the car and then adding it back in. It should ask you if you want to enable CarPlay. I do this regularly with rental cars when I pick them up and then delete my stuff out before I return the car. Hope this helps.
Old Feb 25, 2026 | 05:01 PM
vettel07's Avatar
vettel07
Another thing to reset is the iPhone’s network settings. Wireless CarPlay uses WiFi to connect. Erasing network settings on your iPhone might help. To do that go to settings, then general, then reset & transfer, then reset. It will bring up a window asking what settings to reset. Tap o network settings. The iPhone will reboot then try to pair again. The downside is it will forget all WiFi networks. Good luck.
Old Feb 25, 2026 | 07:41 PM
CorvetteJack0123's Avatar
CorvetteJack0123
Default Multiple Cars causing Car Play issue ?
My 23 Stingray was the 1st car I had connected with Apple Car Play and for 2 years and 2 iPhones never had a problem connecting.
After getting my Blackwing and connecting it with Car Play I now have random issues sometimes connecting in both cars - just assumed the iPhone was getting confused between the 2 cars.
When it happens I just shut down the iPhone and turn it back on and it immediately connects and works. It might connect okay in both cars for 2 weeks or 2 months until it happens again.
Old Feb 26, 2026 | 02:08 AM
JeBC8's Avatar
JeBC8
Can't I just install a cassette or CD player?
Old Feb 26, 2026 | 08:37 AM
Samuel Clemens's Avatar
Samuel Clemens
Yes but an 8 track player will not fit. Ask me how I know. Sam
Old Feb 26, 2026 | 08:38 AM
Samuel Clemens
I actually miss the simplicity of a CD player. Sam
Old Feb 26, 2026 | 09:36 AM
JRYELLOWCORVETTE
Thanks for all the suggestions. I will give them a try starting with the simple ones first.
Old Feb 26, 2026 | 09:57 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Along with the suggested steps provided by other users, we also advise ensuring compatibility is in check by attempting these steps
1. Vehicle is in Park.
2. iPhone is running iOS 7.1 or higher, with Siri AND Wi-Fi enabled
3. CarPlay is turned on in both your vehicle settings and iPhone Screen Time restrictions.
4. Use a certified Apple Lightning USB cable (if using wired connection)
5. If needed, forget your vehicle in iPhone settings AND your phone in vehicle settings (Settings - General - CarPlay - Your Car - Forget This Car) and reconnect using Bluetooth pairing process.
If CarPlay continues to give you troubles, a dealer inspection may be necessary. You can email our team at socialmedia@gm.com if you'd like assistance connecting with one in your area. Just be sure to include your forum username in the subject line, and provide any relevant information on your C8.
Old Feb 26, 2026 | 10:04 AM
Ken_C8's Avatar
Ken_C8
iOS 7 was released to the public on September 18, 2013
Old Feb 26, 2026 | 10:21 AM
OneMoreVet's Avatar
OneMoreVet
St. Jude Donor '25-'26
Good to know someone from Chevy is listening after dropping a hundred large.
Old Feb 26, 2026 | 10:59 AM
SteveG26-Z51's Avatar
SteveG26-Z51
2026 SR with ios26 is perfect for me so far.
Old Feb 26, 2026 | 02:03 PM
Chupacabraz's Avatar
Chupacabraz
Got a 2025, CarPlay has worked fine since day one for me.
Old Yesterday | 09:24 PM
DanielPierre's Avatar
DanielPierre
6th Gear
I just experienced the same thing for the 1st this morning in my 2023 C8. I contacted OnStar and once I spoke to the 3rd agent she had me try some very basic remedies, as in check my Apple iPhone settings, shut down the engine and open the door, shut down my iPhone and reboot it up again, etc. etc. etc. nothing made any difference.
Why would CarPlay suddenly no longer work even though the system recognized my iPhone and I could make and receive calls? Any input is much appreciated!
Old Yesterday | 09:38 PM
mkel2010's Avatar
mkel2010
Make sure your iPhone has the latest OS updates. Make sure that CarPlay is active for the listing for the Corvette(there is a green slider once you open the CarPlay item for the Corvette. If that doesn't work, try Forget This Car, then reboot the phone and try to pair it to the Corvette again. Also, try a wired connection and see if the same thing happens. If these don't fix the issue, call Apple Support and have them run a remote diagnostic on your phone.
I have zero issues with wireless CarPlay in my 2026.
Old Yesterday | 09:58 PM
DanielPierre
6th Gear
Thanks for the prompt response. I did everything you listed except for “forget this device”. Will try that tomorrow. Again thanks!
To Apple Car Play
