C5 Parts for Sale/Wanted C5 Corvette Performance Parts, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements, OEM, Aftermarket
Sponsored by: C7 Carbon
FS: Apex 18x11 SM-10 BNIB
Old Feb 26, 2026 | 06:49 AM
devanmc436's Avatar
devanmc436
Cruising
Default Apex 18x11 SM-10 BNIB
Brand new Apex 18X11 ET57 5x120.65mm wheels
Test fit 1 wheel but going a different direction
1600 pretty firm, still cheaper than APEX
local pick up or buyer pays shipping
located in grass lake mi but will talk on meeting depending on distance
Old Feb 27, 2026 | 09:44 AM
rob-cyn's Avatar
rob-cyn
Are all 4 the same size ? do you run a wide front fender ?
Old Feb 27, 2026 | 09:46 AM
devanmc436's Avatar
devanmc436
Cruising
They are all the same size.
This should fit fine understock fenders. itll be pretty aggressive, but itll fit.
Old Feb 27, 2026 | 09:56 AM
JHrinsin's Avatar
JHrinsin
Just as a point of reference, I friend run these rims on his C5 with Yokohama A052 tires in the 295/30-18 front and 315/30-18 in the rear sizes on the street all the time. He says a bit more negative front camber helps with the stock front fenders. GLWS!
Old Mar 13, 2026 | 05:19 PM
devanmc436's Avatar
devanmc436
Cruising
bump
Old Mar 15, 2026 | 06:34 PM
206danebmx's Avatar
206danebmx
Could you weigh one of the wheels? I could be interested.
Old Mar 15, 2026 | 06:39 PM
devanmc436's Avatar
devanmc436
Cruising
I dont have a very good way to weigh them at home, but apex lists them as 22.5 lbs. so they should be about that.
Old Today | 05:57 AM
devanmc436's Avatar
devanmc436
Cruising
bump
To Apex 18x11 SM-10 BNIB
