[C2] Body mount replacement
Old Mar 19, 2026 | 08:24 AM
hardrock740's Avatar
hardrock740
Default Body mount replacement
I plan on replacing the fuel line and body mounts on my 64 convertible and have researched the subject on this forum. i have the car on jack stands and plan to lift one side replace parts than the other.i have a question about what bolts i need to remove at the front end of car. I removed the 2 bolts connecting the radiator housing to the frame. i've read to also remove the four side bolts connecting the radiator housing to the wheel wells ? Do i need to remove the four side bolts at the radiator housing ? there are also two braces coming off of the bottom of the housing fastened to the grill area that were not mentioned to be removed in any posts i researched. Seems to me from a structural stand point the four side bolts would keep the front end stabilized while lifting the body. But what do i know , just looking for some insight.
Any information would be greatly appreciated. thanks
2 side bolts
2 side bolts
Brace to headlight housing
Old Mar 19, 2026 | 09:09 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Bumper brackets for sure. Steering column at rag joint Not sure if clutch linkage will give enough
Old Mar 19, 2026 | 10:07 AM
Factoid's Avatar
Factoid
I removed the core support and the headlight supports when I replaced my body mounts, but I was also replacing the engine and radiator. I’m not sure if that is really required.
Old Mar 19, 2026 | 02:13 PM
DansYellow66's Avatar
DansYellow66
I know of no reason for removing the radiator support side bolts, to lift the body.
Old Mar 19, 2026 | 03:32 PM
66jack's Avatar
66jack
You Cannot replace the steel fuel line unless you remove body, as the line goes into the frame at the kick up and out by the fuel tank, sender unit...
Check the fuel filler splash rubber, when you lift body from side to side, to make sure it has not shifted..
Old Mar 19, 2026 | 07:04 PM
hardrock740
thanks for the replies. I'm going to lift body evenly off frame just enough to replace fuel line.
Old Mar 19, 2026 | 09:48 PM
66jack's Avatar
66jack
To do the line, you'll need to raise the body at least 2 feet...
To do it correctly..the line has to lift and twist, twist it like a screw to feed it in and out, out and in from the position inside of the frame...
63-67 Fuel Line - Fuel Tank To Pump With Spiral Armor 327 Stainless Steel
Old Mar 19, 2026 | 10:39 PM
Factoid's Avatar
Factoid
I lifted my ‘64 body about this far, removed the fuel line and replaced it.
About six inches.
About six inches.
Old Mar 21, 2026 | 04:35 PM
66jack's Avatar
66jack
Confused...
You're saying the fuel line on a 65 ran outside the frame at the kick-up?
Old Mar 21, 2026 | 05:14 PM
Factoid's Avatar
Factoid
Mine is a ‘64 and all C2 corvette fuel lines go through the frame at the kick up. Once the body is up a few inches, you can straighten the bend in the line at the end, feed it through the frame, and rebend it once it is in place. Even SS lines have a lot of wiggle room.
Old Mar 23, 2026 | 07:04 AM
Con's Avatar
Con
and don't forget the frame bushing that protects the line as it passes through the frame.
Old Mar 23, 2026 | 11:57 AM
twhanks's Avatar
twhanks
Great subject! Watching with interest as I consider something similar on my '66 coupe.
Old Today | 07:02 PM
hardrock740
This is how high off the frame I was to replace the fuel line. It was not fun but I got it done.
Got some parts powder coated and installed a new Dewitt’s. Nice fit well made.
[img alt="Sent my horns out to get restored with the horn guy
Soon as they arrive I’ll be cruising again "]https://cimg5.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/2000x1504/img_5488_c9d5d0cb378f2d2a30e41f474c6b7f4 2b897119a.jpeg[/img]
Sent my horns out to get restored with the horn guy Soon as they arrive I’ll be cruising again
Old Today | 08:07 PM
Factoid's Avatar
Factoid
Nicely done!
To Body mount replacement
