License plate placement
Old Yesterday | 11:33 AM
Sportsman2003's Avatar
Sportsman2003
Default License plate placement
I am tired of getting pulled over for no front plate here in California. I really do not want to put the plate in the middle of the grill. I like this placement. I’m thinking about adding some fiberglass to the inside of the splitter to strengthen it a bit and drilling holes to mount the plate right to it. I’d likely use a bit of double sided tape as well. I will get a rubber plate frame also that covers the entire back side of the plate.
My other option would be to buy the ACS under tray system and use some L brackets off of it to accomplish the same goals.
what are your guys thoughts?
Check out my instagram page C7Z_by_me
Old Yesterday | 11:36 AM
kodpkd's Avatar
kodpkd
It still probably doesn't meet California rules. I feel your pain.
Old Yesterday | 11:57 AM
Sportsman2003
The law just says it has to be on the front of the vehicle and no higher that 60" I think it will work.
Old Yesterday | 12:53 PM
fyreline's Avatar
fyreline
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
I know you said you would rather not mount it in the middle, but I've had mine there since new and it doesn't bother me (or seemingly anyone else) at all. Mounting it off to the side just looks odd to me. Your car, your money, your choice.
Old Yesterday | 01:02 PM
Sportsman2003
Thanks for the feed back and also the reminder of why I will not use the factory mount.
Old Yesterday | 01:59 PM
JLSuperfly's Avatar
JLSuperfly
I have the Sto and Go. Works great.
Old Yesterday | 02:13 PM
Sportsman2003
Can you post a pic of it mounted?
Old Yesterday | 02:26 PM
pifo1964's Avatar
pifo1964
I also need a front plate and this was very useful for me. Mounts with the same existing screws.
https://www.ebay.com/itm/11250897482...mis&media=MORE
Old Yesterday | 02:38 PM
Sportsman2003
I am not sure this will work with the stage three splitter. It would have to be super low to the ground.
Old Yesterday | 02:57 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
You are probably going to have problems with that mounting solution. Kalifornia has started using many cameras 📷 to modify motorists behavior, but, more importantly, create revenue.
They are using cameras, using the license plates, to generate civil tickets, for behavior they do not approve of. This goes to the registered owner.
"Optimal License Placement on Your Vehicle
Every car is different, but the rule of thumb is the same: the front plate should be centered on the front bumper. If your car doesn’t have a built-in bracket for the plate, you may need to install one. It’s important to do this correctly to avoid damage to your vehicle and to ensure the plate is securely attached and compliant with the law.
And remember, the plate must be at least 12 inches from the ground to the bottom of the plate, and the letters and numbers should be at least 2 inches tall. That’s so they can be read from a distance. No excuses for not being seen. For more details, check out this comprehensive guide on license plate regulations.
There are many U tube videos on the new vehicle code laws.
Old Yesterday | 03:31 PM
Sportsman2003
It's spelled Commiefornia. I spoke with a local cop and he said it would be fine. I will stop by the CHP office on my way home to verify that info is correct.
I would hate to drill my splitter then have to move the plate.
Old Yesterday | 03:50 PM
pifo1964's Avatar
pifo1964
I'm not sure how high my license plate is from the ground, but arround here, tolls can read it, also security barriers and even the photo tickets. You can always drill a couple of 3/8 holes in the splitter, in fact I did it, since the plate must be there all the time. But that's me, not everyone is willing to drill their splitter
Old Yesterday | 04:10 PM
Sportsman2003
Are you running yours off the the side as well?
Old Yesterday | 04:19 PM
pifo1964's Avatar
pifo1964
Not sure what you are asking. Sorry
Old Yesterday | 04:52 PM
If you have to run a front plate, the factory aero plate license plate holder works great. It follows the contour of the grill with a little bending of the plate and looks good in the process. But, if that is not to your taste, mount it how you feel best.
Old Yesterday | 04:55 PM
IA-SteveB's Avatar
IA-SteveB
^^^ I agree
I don't mind the Aeroplate, but I did have to get a new one when I switched to a Z06 grille.
My state requires it and they are FINALLY loosening window tint restrictions, but not by much. 70% down to 50%.
Old Yesterday | 05:13 PM
yaknow's Avatar
yaknow
Sto and go, has been my go to
To License plate placement
Old Yesterday | 05:55 PM
Bill Dearborn's Avatar
Bill Dearborn
I prefer the stock Aero Plate holder. No drilling required, and it looks designed to fit the car. Not an afterthought. If you are considering a Sto and Go make sure it fits your Stage 3 front splitter, especially if you have the stock Stage 2/3 undertray. The stock Stage 2/3 front splitter with undertray is basically a flat panel that runs from the front edge of the splitter to the rear of the undertray, which ends at the front edge of the wheel well openings. The Sto and Go is designed to fit the Stage 1 front splitter, so it may not work with the higher stages without some massaging.
Bill
Old Yesterday | 06:00 PM
LT1 Z51's Avatar
LT1 Z51
Stick Shift Enthusiast
You can tell we here in Michigan don't think of front plates until we get reminded by the homologation police that we need to add them to sell cars in some states. Designers and engineers HATE the front plate (for different reasons, for engineers its because it f's with air flow). So it's an after thought thrown on at the "last minute" to a design.
European cars since the plate is standard, European OEMs basically design it into the front end. Well most do.
Old Yesterday | 06:03 PM
rileyhBat's Avatar
rileyhBat
5th Gear
I am curious whereabouts you are in California that they’re pulling you over. I have seen/heard of a few “fix it” tickets handed out, but never pulling someone over for this in the San Francisco Bay Area.
